imx8dx linux driver v4l2 Support NV21 format
1,903 次查看
songhongliang
HI
I now hope that the v4l2 driver of imx8dx can support the format of V4L2_PIX_FMT_NV21, how do I need to modify it to achieve this function. I see that the driver already supports the V4L2_PIX_FMT_NV12 format.
Thanks!
5 回复数
1,898 次查看
joanxie
I don't know capture or output you mean, I assume that you mean capture, so do you mean your input video is format NV21?
1,894 次查看
songhongliang
HI
Yes, it is capture, I am using AHD to mipi chip bridge, I see that 9 capture formats are already supported in the imx8-isi-cap.c file, but format NV21 is not supported. I hope that the video stream in NV21 format can be directly obtained in the application.
Thanks!
1,887 次查看
joanxie
the format from chip bridge is NV21 or you need to convert the input video to NV21?
1,884 次查看
songhongliang
1,870 次查看
joanxie
what is your real capture data? do you need convert raw data to NV12? if yes, you can use software ISP do this,
"https://www.nxp.com.cn/docs/en/application-note/AN12060.pdf"
