i am trying to build image for imx8mmevk machine (imx8M mini) using
bitbake core-image-minimal
i am unable to find wic.bz2 image in tmp/deploy/images/imx8mmevk/
how to add this support?
Solved! Go to Solution.
Hi @kajolkharbanda,
I hope you are doing well.
Please mention the yocto release you are using & step followed.
One can try adding the below line in local.conf
IMAGE_FSTYPES += " wic.bz2 "
Thanks & Regards,
Dhruvit Vasavada
Hi @kajolkharbanda,
Thanks & Regards,
Dhruvit Vasavada
how to clean the build?
if i have made print changes in some kernel source files,
how to build clean to reflect the changes.
Hi @kajolkharbanda,
One should create a patch and add it to the SRC_URI variable of linux-imx recipe.
Please move the custom patch to /sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx.
Please add below line in /sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.15.bb
FILESEXTRAPATHS:prepend := "${THISDIR}/${PN}:"
SRC_URI += "file://0001-custom-changes.patch \
Please run below commands.
$ bitbake linux-imx
$ bitbake <image>
Thanks & Regards,
Dhruvit Vasavada
