imx8: how to run opencv sample code on imx8mq GPU
4,799 次查看
vsuneja63
I could run eIQ OpenCV object detection c++ sample code on imx8mq evk. I want to run the same code on imx8 target gpu. As i am trying object detection with live camera, I didn't get anything with OpenCL. Can you please guide me on this?
Thanks & Regards,
Vipul Kumar
4,620 次查看
joanxie
maybe you can refer to the ISP code, which used openCL on imx8m
https://www.nxp.com/docs/en/application-note/AN12060.pdf
the source code is:
gtec-demo-framework/DemoApps/OpenCL/SoftISP/source at master · NXPmicro/gtec-demo-framework · GitHub
you also can find the demo in the bsp, the path is:
 /opt/imx-gpu-sdk/OpenCL/SoftISP
