Hi Igorpadykov:
Thanks for your reply. It seems that my problem is not same with the one you discussed above. I think if SD1 cmd and clock pinmux value were not set correct. In dts file imx6ul-14*14-evk.dts, I usethe pinmuxs as follows referenced from demo board:
pinctrl_usdhc1:usdhc1grp{
MX6UL_PAD_SD1_CMD_USDHC1_CMD 0x17059
MX6UL_PAD_SD1_CLK_USDHC1_CLK 0x10071
MX6UL_PAD_SD1_DATA0_USDHC1_DATA0 0x17059
MX6UL_PAD_SD1_DATA1_USDHC1_DATA1 0x17059
MX6UL_PAD_SD1_DATA2_USDHC1_DATA2 0x17059
MX6UL_PAD_SD1_DATA3_USDHC1_DATA3 0x17059
So, are the values above acorrding to the hardware designing? and shouled I modify them?
Thanks very much.
