imx6q-pcie: phy link never came up, DEBUG_R0: 0x00ea6102, DEBUG_R1: 0x08200000
997件の閲覧回数
wiking
Observed Phenomenon
Initially, the Wi-Fi module of the device functions normally. However, after approximately two years of use, Wi-Fi-related issues occur. At first, it was suspected that the problem lay with the Wi-Fi module; yet, the same issue persisted even after replacing the Wi-Fi module.
Description
    1. The interface of the device's Wi-Fi module is PCIe.
    2. The Wi-Fi module uses the PCIe-1 interface of the iMX8 chip (PCIe ports are numbered starting from 1 in the circuit diagram), while PCIe ports in the code are numbered starting from 0. Therefore, it corresponds to "pcie0" in the code.
Logs are as follows:
imx6q-pcie 33800000.pcie: imx pcie probe
OF: PCI: host bridge /pcie@0x33800000 ranges:
OF: PCI:   No bus range found for /pcie@0x33800000, using [bus 00-ff]
OF: PCI:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
OF: PCI:   MEM 0x18000000..0x1fefffff -> 0x18000000
imx6q-pcie 33800000.pcie: pcie phy pll is locked.
imx6q-pcie 33800000.pcie: phy link never came up
imx6q-pcie 33800000.pcie: DEBUG_R0: 0x00ea6102, DEBUG_R1: 0x08200000
2 返答(返信)
903件の閲覧回数
danielchen
For the debug info, it is the LTSSM state,  a state machine  defined by the PCI express specification that governs how a PCIe link is established, trained, and maintained.  it transitions through various states during link initialization and operation.
Here are the most common LTSSM states and their hex codes:
Hex Code LTSSM State Description
0x00 DETECT_QUIET No electrical activity detected
0x01 DETECT_ACTIVE Trying to detect receiver
0x02 POLL_ACTIVE Sending TS1 ordered sets
0x03 POLL_COMPLIANCE Compliance pattern testing
0x04 POLL_CONFIG Sending TS2 ordered sets
0x07 CFG_LINKWD_START Starting link width configuration
0x08 CFG_LINKWD_ACCEPT Accepting link width
0x09 CFG_LANENUM_WAIT Waiting for lane number config
0x0A CFG_LANENUM_ACCEPT Accepting lane number config
0x0B CFG_COMPLETE Configuration complete
0x11 L0 Link is up and active
0x12 L0s Low power idle state
0x13 L1 Deeper power saving state
0x17 DISABLED_ENTRY Entering disabled state
0x18 DISABLED_IDLE Disabled but idle
0x19 DISABLED Fully disabled
0x1E HOT_RESET_ENTRY Entering hot reset
0x1F HOT_RESET In hot reset
when your log shows
You can extract the LTSSM state from the lowest byte, (0x02  in this case).
0x02 → POLL_ACTIVE → The controller is sending TS1 ordered sets but not receiving a valid response from the endpoint.
This means the PCIe link is stuck in the polling phase, likely due to:
  • Endpoint not responding (e.g., Wi-Fi module not powered or reset properly),
  • Signal integrity issues,
  • Clock or reset timing problems.
965件の閲覧回数
wiking
SoC: MCIMX8MQ6DVAJZAA
linux-imx:  v4.14.98
dts: fsl-imx8mq-evk.dts
%3CLINGO-SUB%20id%3D%22lingo-sub-2184612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx6q-pcie%3A%20%E7%89%A9%E7%90%86%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81DEBUG_R0%3A%200x00ea6102%E3%80%81DEBUG_R1%3A%200x08200000%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-1275501787%22%20id%3D%22toc-hId-1299483604%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3E%E8%A6%B3%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E7%8F%BE%E8%B1%A1%3C%2FFONT%3E%3C%2FH1%3E%3CDIV%20class%3D%22%22%3E%E6%9C%80%E5%88%9D%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%20Wi-Fi%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%B4%842%E5%B9%B4%E7%B5%8C%E3%81%A4%E3%81%A8%E3%80%81Wi-Fi%E9%96%A2%E9%80%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AF%20Wi-Fi%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E7%96%91%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Wi-Fi%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%A6%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CH1%20id%3D%22toc-hId--531952676%22%20id%3D%22toc-hId--507970859%22%3E%3CFONT%20size%3D%224%22%3E%E8%AA%AC%E6%98%8E%3C%2FFONT%3E%3C%2FH1%3E%3COL%3E%3COL%3E%3CLI%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%20Wi-Fi%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AF%20PCIe%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EWi-Fi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AFiMX8%E3%83%81%E3%83%83%E3%83%97%E3%81%AEPCIe-1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%A7%E3%81%AFPCIe%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF1%E3%81%8B%E3%82%89%E7%95%AA%E5%8F%B7%E3%81%8C%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%E4%B8%80%E6%96%B9%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AEPCIe%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF0%E3%81%8B%E3%82%89%E7%95%AA%E5%8F%B7%E3%81%8C%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E3%80%8Cpcie0%E3%80%8D%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%3E%E3%83%AD%E3%82%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3Eimx6q-pcie%2033800000.pcie%3A%20imx%20pcie%20probe%0AOF%3A%20PCI%3A%20host%20bridge%20%2Fpcie%400x33800000%20ranges%3A%0AOF%3A%20PCI%3A%20%20%20No%20bus%20range%20found%20for%20%2Fpcie%400x33800000%2C%20using%20%5Bbus%2000-ff%5D%0AOF%3A%20PCI%3A%20%20%20%20IO%200x1ff80000..0x1ff8ffff%20-%26gt%3B%200x00000000%0AOF%3A%20PCI%3A%20%20%20MEM%200x18000000..0x1fefffff%20-%26gt%3B%200x18000000%0Aimx6q-pcie%2033800000.pcie%3A%20pcie%20phy%20pll%20is%20locked.%0Aimx6q-pcie%2033800000.pcie%3A%20phy%20link%20never%20came%20up%0Aimx6q-pcie%2033800000.pcie%3A%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx6q-pcie%3A%20phy%20link%20never%20came%20up%2C%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20LTSSM%20%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PCIe%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E7%A2%BA%E7%AB%8B%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E7%B6%AD%E6%8C%81%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%80%81PCI%20Express%20%E4%BB%95%E6%A7%98%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8A%E3%82%88%E3%81%B3%E6%93%8D%E4%BD%9C%E4%B8%AD%E3%81%AB%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E7%8A%B6%E6%85%8B%E3%82%92%E9%81%B7%E7%A7%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%20LTSSM%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A8%E3%81%9D%E3%81%AE%2016%20%E9%80%B2%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20class%3D%22___i31lg00%20f10pi13n%20f14t3ns0%20f1nbblvp%20fat0sn4%20f1ov4xf1%20fekwl8i%20f1lmfglv%20f1oz7aqm%20f1abmfm4%20f1w619qj%20f16h0jq8%22%3E%0A%3CTABLE%20class%3D%22___1hm93bs%20f1ddd56o%20f16vktn6%20f1enuhaj%20fdclmfp%20f1ev3kgc%20ftgm304%20f1uinfot%20fibjyge%20fvueend%20f9yszdx%20f1fu4s3n%20f3l3pb3%20f1s2k7dp%20f8fmt76%20fjvbh62%20fysh76l%20fic4ptz%20f1yenhzu%20f1yn6nvh%20f14tj6oe%20f1jq587y%20f1el8yx3%20f1pymoxg%20f1ofu761%20fe6itr%20f7coize%20f1794535%20f70r78m%20f4zgifc%20fk1v6el%20f16pyhcb%20fo436u6%20fzy4j18%20fc43013%20f1hmrcvb%20fc4t9fq%20fgp09rh%20fjnyn6r%22%20tabindex%3D%220%22%3E%0A%3CTHEAD%3E%0A%3CTR%3E%0A%3CTH%3E16%E9%80%B2%E3%82%B3%E3%83%BC%E3%83%89%3C%2FTH%3E%0A%3CTH%3ELTSSM%E5%B7%9E%3C%2FTH%3E%0A%3CTH%3E%E8%AA%AC%E6%98%8E%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x00%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E9%9D%99%E3%81%8B%E3%81%AB%E6%A4%9C%E5%87%BA%3C%2FTD%3E%0A%3CTD%3E%E9%9B%BB%E6%B0%97%E7%9A%84%E6%B4%BB%E5%8B%95%E3%81%AF%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x01%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E6%A4%9C%E5%87%BA%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FTD%3E%0A%3CTD%3E%E5%8F%97%E4%BF%A1%E6%A9%9F%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x02%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E6%8A%95%E7%A5%A8%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FTD%3E%0A%3CTD%3ETS1%E9%A0%86%E5%BA%8F%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E9%80%81%E4%BF%A1%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x03%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EPOLL_COMPLIANCE%3C%2FTD%3E%0A%3CTD%3E%E3%82%B3%E3%83%B3%E3%83%97%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%82%B9%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%83%86%E3%82%B9%E3%83%88%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x04%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E6%A7%8B%E6%88%90%3C%2FTD%3E%0A%3CTD%3ETS2%E9%A0%86%E5%BA%8F%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E9%80%81%E4%BF%A1%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x07%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_LINKWD_START%3C%2FTD%3E%0A%3CTD%3E%E9%96%8B%E5%A7%8B%E3%83%AA%E3%83%B3%E3%82%AF%E5%B9%85%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x08%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_LINKWD_ACCEPT%3C%2FTD%3E%0A%3CTD%3E%E3%83%AA%E3%83%B3%E3%82%AF%E5%B9%85%E3%81%AE%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x09%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_LANENUM_WAIT%3C%2FTD%3E%0A%3CTD%3E%E8%BB%8A%E7%B7%9A%E7%95%AA%E5%8F%B7%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x0A%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_LANENUM_ACCEPT%3C%2FTD%3E%0A%3CTD%3E%E8%BB%8A%E7%B7%9A%E7%95%AA%E5%8F%B7%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%89%BF%E8%AA%8D%E4%B8%AD%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x0B%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_%E5%AE%8C%E4%BA%86%3C%2FTD%3E%0A%3CTD%3E%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x11%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL0%3C%2FTD%3E%0A%3CTD%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%99%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x12%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL0s%3C%2FTD%3E%0A%3CTD%3E%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x13%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL1%3C%2FTD%3E%0A%3CTD%3E%E3%82%88%E3%82%8A%E6%B7%B1%E3%81%84%E7%9C%81%E9%9B%BB%E5%8A%9B%E7%8A%B6%E6%85%8B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x17%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3C%2FTD%3E%0A%3CTD%3E%E7%84%A1%E5%8A%B9%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x18%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E7%84%A1%E5%8A%B9_%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%3C%2FTD%3E%0A%3CTD%3E%E7%84%A1%E5%8A%B9%E3%81%A0%E3%81%8C%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x19%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E3%83%87%E3%82%A3%E3%82%BB%E3%83%BC%E3%83%96%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%3C%2FTD%3E%0A%3CTD%3E%E5%AE%8C%E5%85%A8%E3%81%AB%E7%84%A1%E5%8A%B9%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x1E%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%3C%2FTD%3E%0A%3CTD%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x1F%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FTD%3E%0A%3CTD%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E4%B8%AD%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3Eimx6q-pcie%2033800000.pcie%3A%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELTSSM%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AF%E3%80%81%E6%9C%80%E4%B8%8B%E4%BD%8D%E3%83%90%E3%82%A4%E3%83%88%20(%E3%81%93%E3%81%AE%20CASE%20%E3%81%AF%200x02)%20%E3%81%8B%E3%82%89%E6%8A%BD%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CCODE%20translate%3D%22no%22%3E0x02%3C%2FCODE%3E%20%E2%86%92%20%3CCODE%20translate%3D%22no%22%3EPOLL_ACTIVE%3C%2FCODE%3E%20%E2%86%92%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AF%20TS1%20%E9%A0%86%E5%BA%8F%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E6%9C%89%E5%8A%B9%E3%81%AA%E5%BF%9C%E7%AD%94%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PCIe%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%3C%2FSTRONG%3E%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%81%93%E3%81%A8%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8C%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%AA%E3%81%84%EF%BC%88%E4%BE%8B%EF%BC%9AWi-Fi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%EF%BC%89%E3%80%81%3C%2FLI%3E%0A%3CLI%3E%E4%BF%A1%E5%8F%B7%E6%95%B4%E5%90%88%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%81%3C%2FLI%3E%0A%3CLI%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
