imx6q-pcie: phy link never came up, DEBUG_R0: 0x00ea6102, DEBUG_R1: 0x08200000
982 次查看
wiking
Observed Phenomenon
Initially, the Wi-Fi module of the device functions normally. However, after approximately two years of use, Wi-Fi-related issues occur. At first, it was suspected that the problem lay with the Wi-Fi module; yet, the same issue persisted even after replacing the Wi-Fi module.
Description
    1. The interface of the device's Wi-Fi module is PCIe.
    2. The Wi-Fi module uses the PCIe-1 interface of the iMX8 chip (PCIe ports are numbered starting from 1 in the circuit diagram), while PCIe ports in the code are numbered starting from 0. Therefore, it corresponds to "pcie0" in the code.
Logs are as follows:
imx6q-pcie 33800000.pcie: imx pcie probe
OF: PCI: host bridge /pcie@0x33800000 ranges:
OF: PCI:   No bus range found for /pcie@0x33800000, using [bus 00-ff]
OF: PCI:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
OF: PCI:   MEM 0x18000000..0x1fefffff -> 0x18000000
imx6q-pcie 33800000.pcie: pcie phy pll is locked.
imx6q-pcie 33800000.pcie: phy link never came up
imx6q-pcie 33800000.pcie: DEBUG_R0: 0x00ea6102, DEBUG_R1: 0x08200000
888 次查看
danielchen
For the debug info, it is the LTSSM state,  a state machine  defined by the PCI express specification that governs how a PCIe link is established, trained, and maintained.  it transitions through various states during link initialization and operation.
Here are the most common LTSSM states and their hex codes:
Hex Code LTSSM State Description
0x00 DETECT_QUIET No electrical activity detected
0x01 DETECT_ACTIVE Trying to detect receiver
0x02 POLL_ACTIVE Sending TS1 ordered sets
0x03 POLL_COMPLIANCE Compliance pattern testing
0x04 POLL_CONFIG Sending TS2 ordered sets
0x07 CFG_LINKWD_START Starting link width configuration
0x08 CFG_LINKWD_ACCEPT Accepting link width
0x09 CFG_LANENUM_WAIT Waiting for lane number config
0x0A CFG_LANENUM_ACCEPT Accepting lane number config
0x0B CFG_COMPLETE Configuration complete
0x11 L0 Link is up and active
0x12 L0s Low power idle state
0x13 L1 Deeper power saving state
0x17 DISABLED_ENTRY Entering disabled state
0x18 DISABLED_IDLE Disabled but idle
0x19 DISABLED Fully disabled
0x1E HOT_RESET_ENTRY Entering hot reset
0x1F HOT_RESET In hot reset
when your log shows
You can extract the LTSSM state from the lowest byte, (0x02  in this case).
0x02 → POLL_ACTIVE → The controller is sending TS1 ordered sets but not receiving a valid response from the endpoint.
This means the PCIe link is stuck in the polling phase, likely due to:
  • Endpoint not responding (e.g., Wi-Fi module not powered or reset properly),
  • Signal integrity issues,
  • Clock or reset timing problems.
950 次查看
wiking
SoC: MCIMX8MQ6DVAJZAA
linux-imx:  v4.14.98
dts: fsl-imx8mq-evk.dts
%3CLINGO-SUB%20id%3D%22lingo-sub-2184612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx6q-pcie%3A%20phy%20link%20never%20came%20up%2C%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-1275501787%22%20id%3D%22toc-hId-1299483511%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3E%E8%A7%82%E5%AF%9F%E5%88%B0%E7%9A%84%E7%8E%B0%E8%B1%A1%3C%2FFONT%3E%3C%2FH1%3E%3CDIV%20class%3D%22%22%3E%E6%9C%80%E5%88%9D%EF%BC%8C%E8%AE%BE%E5%A4%87%E7%9A%84Wi-Fi%E6%A8%A1%E5%9D%97%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%A7%E7%BA%A6%E4%B8%A4%E5%B9%B4%E5%90%8E%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%8E%20Wi-Fi%20%E6%9C%89%E5%85%B3%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E8%B5%B7%E5%88%9D%EF%BC%8C%E4%BA%BA%E4%BB%AC%E6%80%80%E7%96%91%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%20Wi-Fi%20%E6%A8%A1%E5%9D%97%E4%B8%8A%EF%BC%9B%E7%84%B6%E8%80%8C%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%9B%B4%E6%8D%A2%E4%BA%86%20Wi-Fi%20%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FDIV%3E%3CH1%20id%3D%22toc-hId--531952676%22%20id%3D%22toc-hId--507970952%22%3E%3CFONT%20size%3D%224%22%3E%E8%AF%B4%E6%98%8E%3C%2FFONT%3E%3C%2FH1%3E%3COL%3E%3COL%3E%3CLI%3E%E8%AF%A5%E8%AE%BE%E5%A4%87%E7%9A%84%20Wi-Fi%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%8E%A5%E5%8F%A3%E6%98%AF%20PCIe%E3%80%82%3C%2FLI%3E%3CLI%3EWi-Fi%20%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8%20iMX8%20%E8%8A%AF%E7%89%87%E7%9A%84%20PCIe-1%20%E6%8E%A5%E5%8F%A3%EF%BC%88%E7%94%B5%E8%B7%AF%E5%9B%BE%E4%B8%AD%20PCIe%20%E7%AB%AF%E5%8F%A3%E4%BB%8E%201%20%E5%BC%80%E5%A7%8B%E7%BC%96%E5%8F%B7%EF%BC%89%EF%BC%8C%E8%80%8C%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%20PCIe%20%E7%AB%AF%E5%8F%A3%E4%BB%8E%200%20%E5%BC%80%E5%A7%8B%E7%BC%96%E5%8F%B7%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AE%83%E5%AF%B9%E5%BA%94%E4%BA%8E%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%22pcie0%22%20%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%3E%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3Eimx6q-pcie%2033800000.pcie%3A%20imx%20pcie%20probe%0AOF%3A%20PCI%3A%20host%20bridge%20%2Fpcie%400x33800000%20ranges%3A%0AOF%3A%20PCI%3A%20%20%20No%20bus%20range%20found%20for%20%2Fpcie%400x33800000%2C%20using%20%5Bbus%2000-ff%5D%0AOF%3A%20PCI%3A%20%20%20%20IO%200x1ff80000..0x1ff8ffff%20-%26gt%3B%200x00000000%0AOF%3A%20PCI%3A%20%20%20MEM%200x18000000..0x1fefffff%20-%26gt%3B%200x18000000%0Aimx6q-pcie%2033800000.pcie%3A%20pcie%20phy%20pll%20is%20locked.%0Aimx6q-pcie%2033800000.pcie%3A%20phy%20link%20never%20came%20up%0Aimx6q-pcie%2033800000.pcie%3A%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx6q-pcie%3A%20phy%20link%20never%20came%20up%2C%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%AE%83%E6%98%AF%20LTSSM%20%E7%8A%B6%E6%80%81%EF%BC%8C%E8%BF%99%E6%98%AF%20PCI%20Express%20%E8%A7%84%E8%8C%83%E5%AE%9A%E4%B9%89%E7%9A%84%E7%8A%B6%E6%80%81%E6%9C%BA%EF%BC%8C%E7%94%A8%E4%BA%8E%E7%AE%A1%E7%90%86%20PCIe%20%E9%93%BE%E6%8E%A5%E7%9A%84%E5%BB%BA%E7%AB%8B%E3%80%81%E8%AE%AD%E7%BB%83%E5%92%8C%E7%BB%B4%E6%8A%A4%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%9C%80%E5%B8%B8%E8%A7%81%E7%9A%84%20LTSSM%20%E7%8A%B6%E6%80%81%E5%8F%8A%E5%85%B6%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20class%3D%22___i31lg00%20f10pi13n%20f14t3ns0%20f1nbblvp%20fat0sn4%20f1ov4xf1%20fekwl8i%20f1lmfglv%20f1oz7aqm%20f1abmfm4%20f1w619qj%20f16h0jq8%22%3E%0A%3CTABLE%20class%3D%22___1hm93bs%20f1ddd56o%20f16vktn6%20f1enuhaj%20fdclmfp%20f1ev3kgc%20ftgm304%20f1uinfot%20fibjyge%20fvueend%20f9yszdx%20f1fu4s3n%20f3l3pb3%20f1s2k7dp%20f8fmt76%20fjvbh62%20fysh76l%20fic4ptz%20f1yenhzu%20f1yn6nvh%20f14tj6oe%20f1jq587y%20f1el8yx3%20f1pymoxg%20f1ofu761%20fe6itr%20f7coize%20f1794535%20f70r78m%20f4zgifc%20fk1v6el%20f16pyhcb%20fo436u6%20fzy4j18%20fc43013%20f1hmrcvb%20fc4t9fq%20fgp09rh%20fjnyn6r%22%20tabindex%3D%220%22%3E%0A%3CTHEAD%3E%0A%3CTR%3E%0A%3CTH%3E%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E4%BB%A3%E7%A0%81%3C%2FTH%3E%0A%3CTH%3ELTSSM%20%E7%8A%B6%E6%80%81%3C%2FTH%3E%0A%3CTH%3E%E8%AF%B4%E6%98%8E%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x00%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EDETECT_QUIET%3C%2FTD%3E%0A%3CTD%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E7%94%B5%E6%B4%BB%E5%8A%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x01%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EDETECT_ACTIVE%3C%2FTD%3E%0A%3CTD%3E%E5%B0%9D%E8%AF%95%E6%A3%80%E6%B5%8B%E6%8E%A5%E6%94%B6%E5%99%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x02%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EPOLL_ACTIVE%3C%2FTD%3E%0A%3CTD%3E%E5%8F%91%E9%80%81%20TS1%20%E6%9C%89%E5%BA%8F%E9%9B%86%E5%90%88%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x03%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E6%8A%95%E7%A5%A8%E5%90%88%E8%A7%84%3C%2FTD%3E%0A%3CTD%3E%E7%AC%A6%E5%90%88%E6%80%A7%E6%A8%A1%E5%BC%8F%E6%B5%8B%E8%AF%95%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x04%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EPOLL_CONFIG%3C%2FTD%3E%0A%3CTD%3E%E5%8F%91%E9%80%81%20TS2%20%E6%9C%89%E5%BA%8F%E9%9B%86%E5%90%88%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x07%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3Ecfg_linkwd_start%3C%2FTD%3E%0A%3CTD%3E%E5%90%AF%E5%8A%A8%E9%93%BE%E8%B7%AF%E5%AE%BD%E5%BA%A6%E9%85%8D%E7%BD%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x08%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3Ecfg_linkwd_accept%3C%2FTD%3E%0A%3CTD%3E%E6%8E%A5%E5%8F%97%E9%93%BE%E6%8E%A5%E5%AE%BD%E5%BA%A6%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x09%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3Ecfg_lanenum_wait%3C%2FTD%3E%0A%3CTD%3E%E7%AD%89%E5%BE%85%E8%BD%A6%E9%81%93%E7%BC%96%E5%8F%B7%E9%85%8D%E7%BD%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x0A%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3Ecfg_lanenum_accept%3C%2FTD%3E%0A%3CTD%3E%E6%8E%A5%E5%8F%97%E8%BD%A6%E9%81%93%E7%BC%96%E5%8F%B7%E9%85%8D%E7%BD%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x0B%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3ECFG_COMPLETE%3C%2FTD%3E%0A%3CTD%3E%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x11%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL0%3C%2FTD%3E%0A%3CTD%3E%E9%93%BE%E6%8E%A5%E5%B7%B2%E5%90%AF%E5%8A%A8%E5%B9%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x12%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL0s%3C%2FTD%3E%0A%3CTD%3E%E4%BD%8E%E5%8A%9F%E8%80%97IDLE%E7%8A%B6%E6%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x13%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EL1%3C%2FTD%3E%0A%3CTD%3E%E6%9B%B4%E6%B7%B1%E7%9A%84%E7%9C%81%E7%94%B5%E7%8A%B6%E6%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x17%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EDISABLED_ENTRY%3C%2FTD%3E%0A%3CTD%3E%E8%BF%9B%E5%85%A5%E7%A6%81%E7%94%A8%E7%8A%B6%E6%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x18%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3EDISABLED_IDLE%3C%2FTD%3E%0A%3CTD%3E%E5%B7%B2%E7%A6%81%E7%94%A8%E4%BD%86%E9%97%B2%E7%BD%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x19%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E7%A6%81%E7%94%A8%3C%2FTD%3E%0A%3CTD%3E%E5%AE%8C%E5%85%A8%E7%A6%81%E7%94%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x1E%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E7%83%AD%E9%87%8D%E7%BD%AE%E5%85%A5%E5%8F%A3%3C%2FTD%3E%0A%3CTD%3E%E8%BF%9B%E5%85%A5%E7%83%ADRESET%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CCODE%20translate%3D%22no%22%3E0x1F%3C%2FCODE%3E%3C%2FTD%3E%0A%3CTD%3E%E7%83%AD%E9%87%8D%E7%BD%AE%3C%2FTD%3E%0A%3CTD%3E%E5%A4%84%E4%BA%8E%E7%83%ADRESET%E7%8A%B6%E6%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BD%93%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%20%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3Eimx6q-pcie%2033800000.pcie%3A%20DEBUG_R0%3A%200x00ea6102%2C%20DEBUG_R1%3A%200x08200000%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%9C%80%E4%BD%8E%E5%AD%97%E8%8A%82%EF%BC%88%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%200x02%EF%BC%89%E6%8F%90%E5%8F%96%20LTSSM%20%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CCODE%20translate%3D%22no%22%3E0x02%3C%2FCODE%3E%20%E2%86%92%3CCODE%20translate%3D%22no%22%3EPOLL_ACTIVE%3C%2FCODE%3E%20%E2%86%92%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%20TS1%20%E6%9C%89%E5%BA%8F%E9%9B%86%EF%BC%8C%E4%BD%86%E6%9C%AA%E6%94%B6%E5%88%B0%E7%AB%AF%E7%82%B9%E7%9A%84%E6%9C%89%E6%95%88%E5%93%8D%E5%BA%94%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20PCIe%20%E9%93%BE%E8%B7%AF%E5%A4%84%E4%BA%8E%3CSTRONG%3E%E8%BD%AE%E8%AF%A2%E9%98%B6%E6%AE%B5%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E7%94%B1%E4%BA%8E%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E7%AB%AF%E7%82%B9%E6%97%A0%E5%93%8D%E5%BA%94%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CWi-Fi%20%E6%A8%A1%E5%9D%97%E6%9C%AA%E9%80%9A%E7%94%B5%E6%88%96%E6%9C%AA%E6%AD%A3%E7%A1%AE%20RESET%EF%BC%89%EF%BC%8C%3C%2FLI%3E%0A%3CLI%3E%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E9%97%AE%E9%A2%98%E3%80%81%3C%2FLI%3E%0A%3CLI%3E%E6%97%B6%E9%92%9F%E6%88%96%20RESET%20%E8%AE%A1%E6%97%B6%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
