imx6 ulz
imx6 ulz
johnot
I just want to know whether  imx6 ulz supports LCD? Has it contains GPU?  Can it support Google Map
gusarambula
Hello John O T,
The i.MX6ULZ is currently in pre-production so I would need to ask you to contact your Distributor or FAE for more information about this part.
You can see the modules of this part in a general manner on the following link.
https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/i.mx-appl...
I hope this helps,
mariocenteno
Hello John,
Please look at the i.MX 6ULZ block diagram.  There is no LCD controller on the i.MX 6ULZ.  You can look at the i.MX 6ULL if you need a LCD controller.
thanks
Mario
