imx6 solo USB module clock gating
hailiu
I am configuring USB clock for imx6solo chip. When I look at the reference manual, the gating of clock iph_ahb_clk (in table 18-3, System clocks, gating, and override) is controlled by CCGR0(CG11). But when I check the register field of CCGR0, it says CG11 controls the CPU_DEBUG_CLK. IS it a typo or the two clocks are the same? There is no clock section in USB chapter as others.
