imx6 DDR3 test
imx6 DDR3 test
1,773 次查看
yzhang
I am new to imx6 and linux as well. As I am trying to test the hardware connection between DDR3 and imx6, I need to run a basic functional test program. But I have no idea of where to start from. I wonder if there is any example test code that helps. Any advice or help is welcome. Really appreciate it. The schematic is shown below for your reference.
Yi
1,566 次查看
yzhang
I found out there is "mtest" command in u-boot, which can do the basic memory test as expected. Kind of solved my problem!
