imx28 create partition
1,575 次查看
wenmintang
My older board have 512M nor flash, and 2 MTD Partition as fllow:
0x000000000000-0x000001400000 : "gpmi-nfc-0-boot"  // linux_ivt_boot
0x000001400000-0x000020000000 : "gpmi-nfc-general-use"  // jffs2 file system
Now I want to change 2G flash ,and want to make 3 MTD partition:
0x000000000000-0x000001400000 : "gpmi-nfc-0-boot" //linux_ivt_boot
0x000001400000-0x000020000000 : "gpmi-nfc-general-use" //jffs2 file system
0x000020000000-xxxxx : "gpmi-nfc-general-date" //ubi file system
How can I do?
1 回复
1,342 次查看
jimmychan
The partition is hardcoded in gpmi-nfc-mil.c.
You may need to modify the gpmi-nfc-mil.c.
Re: i.mx28 nand boot
Or for ubi file system, you can refer this for the ubi commands:
Re: How to setup or change partitions of NAND?
