iMX95 DRAM timing settings
simonng
Hi NXP team,
I want to change the DRAM timing configurations for the iMX95. I think the timing configurations are set by the following codes in the ds file.
freq0 timing 0x5e080100 32 0x020D2100 #TIMING_CFG_3
freq0 timing 0x5e080104 32 0x4866000C #TIMING_CFG_0
freq0 timing 0x5e080108 32 0xF2F08C45 #TIMING_CFG_1
freq0 timing 0x5e08010C 32 0x20488010 #TIMING_CFG_2
freq0 timing 0x5e080124 32 0x0C230308 #DDR_SDRAM_INTERVAL
freq0 timing 0x5e080160 32 0x00000101 #TIMING_CFG_4
freq0 timing 0x5e08016C 32 0x01300000 #TIMING_CFG_7
freq0 timing 0x5e080170 32 0x8B010509 #DDR_ZQ_CNTL
freq0 timing 0x5e080250 32 0x00110A11 #TIMING_CFG_8
freq0 timing 0x5e080254 32 0x00680040 #TIMING_CFG_9
freq0 timing 0x5e080258 32 0x03003E80 #TIMING_CFG_10
freq0 timing 0x5e08025C 32 0x40520200 #TIMING_CFG_11
freq0 timing 0x5e080300 32 0x08110808 #TIMING_CFG_12
freq0 timing 0x5e080304 32 0x00680E02 #TIMING_CFG_13
freq0 timing 0x5e080308 32 0x06040603 #TIMING_CFG_14
freq0 timing 0x5e08030C 32 0x0030001C #TIMING_CFG_15
freq0 timing 0x5e080310 32 0x20610000 #TIMING_CFG_16
freq0 timing 0x5e080314 32 0x0A0A0407 #TIMING_CFG_17
Where can I get the descriptions of the above registers?
Simon
pengyong_zhang
Hi @simonng
Please refer the  DDRC registers description of i.MX93 RM documentation file. i.mx93 and i.mx95 use the same DDRC IP.
B.R
pengyong_zhang
Hi @simonng
B.R
pengyong_zhang
Hi @simonng
We strongly do not recommend you modify the DDR timing parameters by yourself. Because this may cause unpredictable risks.
What is your purpose about this?
B.R
simonng
Hi @pengyong_zhang ,
I need to do some correlation tests on the DRAM devices. So, I want to adjust the timing such as tRCD and tFAW. I want to have the descriptions of the registers. Then I can adjust the value accordingly.
Simon
%3CLINGO-SUB%20id%3D%22lingo-sub-2071790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%20DRAM%20timing%20settings%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20team%2C%3C%2FP%3E%3CP%3EI%20want%20to%20change%20the%20DRAM%20timing%20configurations%20for%20the%20iMX95.%20I%20think%20the%20timing%20configurations%20are%20set%20by%20the%20following%20codes%20in%20the%20ds%20file.%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3Efreq0%20timing%200x5e080100%2032%200x020D2100%20%23TIMING_CFG_3%3CBR%20%2F%3Efreq0%20timing%200x5e080104%2032%200x4866000C%20%23TIMING_CFG_0%3CBR%20%2F%3Efreq0%20timing%200x5e080108%2032%200xF2F08C45%20%23TIMING_CFG_1%3CBR%20%2F%3Efreq0%20timing%200x5e08010C%2032%200x20488010%20%23TIMING_CFG_2%3CBR%20%2F%3Efreq0%20timing%200x5e080124%2032%200x0C230308%20%23DDR_SDRAM_INTERVAL%3CBR%20%2F%3Efreq0%20timing%200x5e080160%2032%200x00000101%20%23TIMING_CFG_4%3CBR%20%2F%3Efreq0%20timing%200x5e08016C%2032%200x01300000%20%23TIMING_CFG_7%3CBR%20%2F%3Efreq0%20timing%200x5e080170%2032%200x8B010509%20%23DDR_ZQ_CNTL%3CBR%20%2F%3Efreq0%20timing%200x5e080250%2032%200x00110A11%20%23TIMING_CFG_8%3CBR%20%2F%3Efreq0%20timing%200x5e080254%2032%200x00680040%20%23TIMING_CFG_9%3CBR%20%2F%3Efreq0%20timing%200x5e080258%2032%200x03003E80%20%23TIMING_CFG_10%3CBR%20%2F%3Efreq0%20timing%200x5e08025C%2032%200x40520200%20%23TIMING_CFG_11%3CBR%20%2F%3Efreq0%20timing%200x5e080300%2032%200x08110808%20%23TIMING_CFG_12%3CBR%20%2F%3Efreq0%20timing%200x5e080304%2032%200x00680E02%20%23TIMING_CFG_13%3CBR%20%2F%3Efreq0%20timing%200x5e080308%2032%200x06040603%20%23TIMING_CFG_14%3CBR%20%2F%3Efreq0%20timing%200x5e08030C%2032%200x0030001C%20%23TIMING_CFG_15%3CBR%20%2F%3Efreq0%20timing%200x5e080310%2032%200x20610000%20%23TIMING_CFG_16%3CBR%20%2F%3Efreq0%20timing%200x5e080314%2032%200x0A0A0407%20%23TIMING_CFG_17%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EWhere%20can%20I%20get%20the%20descriptions%20of%20the%20above%20registers%3F%3C%2FP%3E%3CP%3EThanks%2C%3CBR%20%2F%3ESimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX95%20DRAM%20timing%20settings%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20refer%20the%26nbsp%3B%20DDRC%20registers%20description%20of%20i.MX93%20RM%20documentation%20file.%20i.mx93%20and%20i.mx95%20use%20the%20same%20DDRC%20IP.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX95%20DRAM%20timing%20settings%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20need%20to%20do%20some%20correlation%20tests%20on%20the%20DRAM%20devices.%20So%2C%20I%20want%20to%20adjust%20the%20timing%20such%20as%20tRCD%20and%20tFAW.%20I%20want%20to%20have%20the%20descriptions%20of%20the%20registers.%20Then%20I%20can%20adjust%20the%20value%20accordingly.%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3ESimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX95%20DRAM%20timing%20settings%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWe%20strongly%20do%20not%20recommend%20you%20modify%20the%20DDR%20timing%20parameters%20by%20yourself.%20Because%26nbsp%3Bthis%20may%20cause%20unpredictable%20risks.%3C%2FP%3E%0A%3CP%3EWhat%20is%20your%20purpose%20about%20this%3F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
