iMX95 2D GPU
iMX95 2D GPU
mrudy
I've been reading that the i.MX95 will have a dedicated 2D GPU that can be used by the M7 core.
Will the bare metal VGLite driver provided by NXP support the 2D GPU in the i.MX95?
I see there are lots of examples for using the VGLite driver for the RT line or processors.  Would these apply and work for the M7 and 2D GPU in the i.MX95?
Is the driver for the 2D GPU completely open source, meaning no pre-compiled libraries are required?
yipingwang
There is no VGLite or related support for i.MX95, or other MPU. Also no plan for support that.
I checked the latest SDK(2603), there is g2d+DPU demo. That means the 2d GPU and display has been enabled. For i.MX MPU, 2D GPU is supported by G2D lib.
And you can check the SDK_26_03_00_IMX95LPD5EVK-19\middleware\g2d_dpu\cm7, the g2d lib is released by "libg2d.a", no opensource.
%3CLINGO-SUB%20id%3D%22lingo-sub-2348250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%202D%20GPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20been%20reading%20that%20the%20i.MX95%20will%20have%20a%20dedicated%202D%20GPU%20that%20can%20be%20used%20by%20the%20M7%20core.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EWill%20the%20bare%20metal%20VGLite%20driver%20provided%20by%20NXP%20support%20the%202D%20GPU%20in%20the%20i.MX95%3F%3C%2FP%3E%3CP%3EI%20see%20there%20are%20lots%20of%20examples%20for%20using%20the%20VGLite%20driver%20for%20the%20RT%20line%20or%20processors.%26nbsp%3B%20Would%20these%20apply%20and%20work%20for%20the%20M7%20and%202D%20GPU%20in%20the%20i.MX95%3F%3C%2FP%3E%3CP%3EIs%20the%20driver%20for%20the%202D%20GPU%20completely%20open%20source%2C%20meaning%20no%20pre-compiled%20libraries%20are%20required%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%202D%20GPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere%20is%20no%20VGLite%20or%20related%20support%20for%20i.MX95%2C%20or%20other%20MPU.%20Also%20no%20plan%20for%20support%20that.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EI%20checked%20the%20latest%20SDK(2603)%2C%20there%20is%20g2d%2BDPU%20demo.%20That%20means%20the%202d%20GPU%20and%20display%20has%20been%20enabled.%20For%20i.MX%20MPU%2C%202D%20GPU%20is%20supported%20by%20G2D%20lib.%3C%2FP%3E%0A%3CP%3EAnd%20you%20can%20check%20the%26nbsp%3BSDK_26_03_00_IMX95LPD5EVK-19%5Cmiddleware%5Cg2d_dpu%5Ccm7%2C%20the%20g2d%20lib%20is%20released%20by%20%22libg2d.a%22%2C%20no%20opensource.%3C%2FP%3E%3C%2FLINGO-BODY%3E
