iMX8QM MEK PCEe controller init
1,183件の閲覧回数
rkohli2000
I'm using bl31.bin to handoff control to a test app on the imx8QM MEK. A requirement of our BSP is the initialization of the PCIe controller on exit of the bootloader. Can anyone share the minimal config steps needed to make the PCIe active and enabled ? Is there some init code in SCFW, TF-A I can use to init the PCIe controller ? Thanks in advance.
Ravi
