Dear Team,
SW: Android 11.0.0_1.0.0
HW: iMX8MQ EVK
Module: Camera
I was trying bring up camera on iMX8MQ platform running Android 11. I also tried your demo images however, camera was not working.
Please find the below logs and DTS files attached
1. logcat
2. dmesg
3. DTS files
[ 1.950717] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 1.956876] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at endpoint@0 XXX found
[ 1.964817] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 1.972542] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 1.978698] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at endpoint@0 XXX found
[ 1.986642] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 2, name: mxc-mipi-csi2.1
[ 1.994548] mx6s-csi 30a90000.csi1_bridge: initialising
[ 2.000000] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 2.005831] mx6s-csi 30b80000.csi2_bridge: initialising
[ 2.011264] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 2.017337] uvcvideo: Unable to create debugfs directory
[ 2.022710] usbcore: registered new interface driver uvcvideo
[ 2.028468] USB Video Class driver (1.1.1)
[ 2.595818] ov5640_mipi 0-003c: No sensor reset pin available
[ 2.601615] ov5640_mipi 0-003c: 0-003c supply DOVDD not found, using dummy regulator
[ 2.609454] ov5640_mipi 0-003c: 0-003c supply DVDD not found, using dummy regulator
[ 2.617144] ov5640_mipi 0-003c: 0-003c supply AVDD not found, using dummy regulator
[ 2.682048] random: fast init done
[ 3.709158] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: ov5640_mipi 0-003c
[ 3.719140] ov5640_mipi 0-003c: Camera is found
[ 3.724650] i2c i2c-0: IMX I2C adapter registered
[ 3.738294] ov5640_mipi 1-003c: No sensor reset pin available
[ 3.744386] ov5640_mipi 1-003c: 1-003c supply DOVDD not found, using dummy regulator
[ 3.752445] ov5640_mipi 1-003c: 1-003c supply DVDD not found, using dummy regulator
[ 3.760184] ov5640_mipi 1-003c: 1-003c supply AVDD not found, using dummy regulator
[ 3.777267] ov5640_mipi 1-003c: Read reg error: reg=300a
[ 3.782633] ov5640_mipi 1-003c: Camera is not found
[ 3.787929] i2c i2c-1: IMX I2C adapter registered
Logcat
10-06 12:06:49.180 2783 2783 D CAM_Camera2OneCamMgr: Getting First BACK Camera
10-06 12:06:49.180 2783 2783 I CameraManagerGlobal: Connecting to camera service
10-06 12:06:49.184 2783 2783 D CAM_Camera2OneCamMgr: Getting First FRONT Camera
10-06 12:06:49.186 2783 2783 W CAM_Camera2OneCamMgr: No front-facing camera found.
10-06 12:06:49.188 2783 2783 W CAM_Camera2OneCamMgr: No external camera found.
10-06 12:06:49.189 2783 2783 V CAM_Profiler: [ 53.393ms][ui] GUARD: CameraActivity.onCreateTasks - [11.282ms] OneCameraManager.get
10-06 12:06:49.215 470 1631 I CameraService: CameraService::connect call (PID -1 "com.android.camera2", camera ID 0) for HAL version default and Camera API version 1
10-06 12:06:49.215 470 1631 I Camera2ClientBase: Camera 0: Opened. Client: com.android.camera2 (PID 2783, UID 10100)
10-06 12:06:49.218 369 426 I CameraDeviceSessionHwlImpl: CameraDeviceSessionHwlImpl: this 0xb400f2194fc0a610
10-06 12:06:49.218 369 426 I CameraDeviceSessionHwlImpl: Initialize, meta 0xb400f218dfc0fff0, entry count 63
10-06 12:06:49.218 369 426 I CameraDeviceSessionHwlImpl: Initialize: create video stream for camera mx6s-csi, buffer type 0, path /dev/video1
10-06 12:06:49.218 369 426 I CameraDeviceSessionHwlImpl: Initialize: pVideoStream 0xb400f2195fc0e0b0 created
10-06 12:06:49.225 369 426 D GCH_CameraDeviceSession: FindLibraryPaths: Unable to open directory /vendor/lib64/camera/capture_sessions/ (No such file or directory)
10-06 12:06:49.225 369 426 W GCH_CameraDeviceSession: InitializeZoomRatioMapper: Failed to get the zoom ratio range: No such file or directory(-2)
10-06 12:06:49.225 369 426 I GCH_CameraDeviceSession: Create: Created a device session for camera 0 with 0 physical cameras
10-06 12:06:49.239 470 1631 E Camera2-Parameters: generated preview size list is empty!!
10-06 12:06:49.240 470 1631 E Camera2Client: initializeImpl: Camera 0: unable to build defaults: Invalid argument (-22)
10-06 12:06:49.240 470 1631 E CameraService: connectHelper: Could not initialize client from HAL.
10-06 12:06:49.240 470 1631 I Camera2Client: Camera 0: Closed
10-06 12:06:49.240 470 1631 I Camera3-Device: disconnectImpl: E
10-06 12:06:49.243 369 426 I CameraDeviceSessionHwlImpl: ~CameraDeviceSessionHwlImpl: this 0xb400f2194fc0a610, 0xb400f2191fc0a8d0, 0xb400f2194fc0a688
10-06 12:06:49.244 369 426 I CameraDeviceSessionHwlImpl: ~CameraDeviceSessionHwlImpl, mWorkThread exited
10-06 12:06:49.244 470 1631 I Camera3-Device: disconnectImpl: X
10-06 12:06:49.245 470 1631 I CameraService: disconnect: Disconnected client for camera 0 for PID 2783
10-06 12:06:49.246 470 1631 I Camera2ClientBase: Closed Camera 0. Client was: com.android.camera2 (PID 2783, UID 10100)
10-06 12:06:49.246 470 1631 I Camera3-Device: disconnectImpl: E
10-06 12:06:49.246 2783 2783 W CameraBase: An error occurred while connecting to camera 0: Status(-8, EX_SERVICE_SPECIFIC): '10: connectHelper:1740: Failed to initialize camera "0": No such device (-19)'
10-06 12:06:49.524 2783 2783 I CAM_Profiler: [389.080ms][ui] GUARD: CameraActivity.onCreateTasks - [22.999ms] Init CurrentModule
10-06 12:06:49.533 2783 2783 I CAM_Profiler: [397.434ms][ui] GUARD: CameraActivity.onCreateTasks - STOP
10-06 12:06:49.533 2783 2783 V CAM_QuickActivity: END onCreate: Activity = com.android.camera.CameraActivity@c3c6aa6
10-06 12:06:49.536 2783 2783 V CAM_QuickActivity: START onStart: Activity = com.android.camera.CameraActivity@c3c6aa6
10-06 12:06:49.543 2783 2783 V CAM_QuickActivity: END onStart: Activity = com.android.camera.CameraActivity@c3c6aa6
10-06 12:06:49.546 2783 2783 V CAM_QuickActivity: START onResume: Activity = com.android.camera.CameraActivity@c3c6aa6
10-06 12:06:49.610 2783 2783 V CAM_QuickActivity: END onResume: Activity = com.android.camera.CameraActivity@c3c6aa6
10-06 12:06:49.744 2783 2833 V CAM_CameraDataAdapter: retrieved photo metadata, number of items: 0
10-06 12:06:49.746 2783 2833 V CAM_CameraDataAdapter: retrieved video metadata, number of items: 0
10-06 12:06:49.746 2783 2833 V CAM_CameraDataAdapter: sorting video/photo metadata
10-06 12:06:49.747 2783 2833 V CAM_CameraDataAdapter: sorted video/photo metadata
10-06 12:06:49.919 2783 2783 V CAM_CameraAppUI: SurfaceTexture is available
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: Unable to obtain picture sizes.
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: java.lang.IllegalArgumentException: format 0x0 was not defined in either ImageFormat or PixelFormat
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.params.StreamConfigurationMap.checkArgumentFormat(StreamConfigurationMap.java:1232)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.params.StreamConfigurationMap.checkArgumentFormatInternal(StreamConfigurationMap.java:1206)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.params.StreamConfiguration.<init>(StreamConfiguration.java:62)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.marshal.impl.MarshalQueryableStreamConfiguration$MarshalerStreamConfiguration.unmarshal(MarshalQueryableStreamConfiguration.java:59)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.marshal.impl.MarshalQueryableStreamConfiguration$MarshalerStreamConfiguration.unmarshal(MarshalQueryableStreamConfiguration.java:38)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.marshal.impl.MarshalQueryableArray$MarshalerArray.unmarshal(MarshalQueryableArray.java:93)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.getBase(CameraMetadataNative.java:575)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.getBase(CameraMetadataNative.java:539)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.getStreamConfigurationMap(CameraMetadataNative.java:1301)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.access$400(CameraMetadataNative.java:88)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative$5.getValue(CameraMetadataNative.java:613)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.get(CameraMetadataNative.java:439)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.impl.CameraMetadataNative.get(CameraMetadataNative.java:410)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at android.hardware.camera2.CameraCharacteristics.get(CameraCharacteristics.java:239)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at com.android.camera.one.v2.OneCameraCharacteristicsImpl.getSupportedPictureSizes(OneCameraCharacteristicsImpl.java:63)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at com.android.camera.settings.ResolutionSetting.getPictureSize(ResolutionSetting.java:153)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at com.android.camera.CaptureModule.openCameraAndStartPreview(CaptureModule.java:1363)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at com.android.camera.CaptureModule.access$1900(CaptureModule.java:107)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at com.android.camera.CaptureModule$10.run(CaptureModule.java:653)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
10-06 12:06:52.335 2783 2833 E CAM_OneCamCharImpl: at java.lang.Thread.run(Thread.java:923)
10-06 12:06:52.349 2783 2833 E AndroidRuntime: at com.android.camera.CaptureModule.openCameraAndStartPreview(CaptureModule.java:1363)
10-06 12:06:52.360 563 1028 W ActivityTaskManager: Force finishing activity com.android.camera2/com.android.camera.CameraLauncher
10-06 12:06:52.462 563 1028 I WindowManager: WIN DEATH: Window{cd9e0a1 u0 com.android.camera2/com.android.camera.CameraLauncher}
Please help.
Libin Jose.
