iMX8MPlus EVK KIT Interfacing.
759件の閲覧回数
ReshmaRoy
We are using the iMX8MPlus EVK KIT for validating the  MIPI-DSI Display we are using for our design. We need to interface MINI SAS connector to our DISPLAY board to that in the EVK KIT. So, we checked the mating cable for the MINISAS in EVK KIT Part: 075783-0132 and found that the cable part is obsolete. So we have taken an alternate cable part for the same. Can you please help me with confirming that this cable could be used with the  iMX8MPlus EVK KIT's MINI SAS Connector.
Recommended Part: 0795762102(obsolete)
Alternate Part selected: 8F36-AAA105-0.50 by 3M
744件の閲覧回数
Chavira
HI @ReshmaRoy!
Thank you for contacting NXP Support!
That cable looks compatible with our evk board, however I recommend to  ask to your distributor the compatibility to be sure.
Best Regards!
Chavira
