iMX8MM EVK MINISASTOCSI .dts file
tom_perman
It is my understanding that the MINISASTOCSI (MIPI-CSI Camera Module) is compatible with the iMX8M Mini EVK. See the webpage here: i.MX 8 Series Accessory Boards | NXP
However there doesn't appear to be a .dts file provided in the build to provide support for this. The .dts file "fsl-imx8mq-evk-mipi-csi2.dts" appears to be a close match, but for the iMX8MQ. Have I missed a file or do i need to create a new .dts?
AldoG
There is no need for you to create a new one the default .dtb should work for you
Hope this helps,
Aldo.
AldoG
Hope this helps,
Aldo.
tom_perman
I have realised that the default .dts file already supports the MINISASTOCSI, no changes required
