iMX8M and SATA
iMX8M and SATA
claudiolancone1
Is it possible to connect a 2.5" SATA Harddisk to iMX8M? I don't find any SATA port in documentation, however in reference manual the pciexpress register PCIE_PHY_CMN_REG04 say:
PLL Loop Filter Res control
0011
 Default for SATA
So is SATA supported by PCIexpress port? Is it a software configuration?
Bio_TICFSL
Hi Claudio,
The i.MX8M has no support for SATA, One can Use the PCI for SATA, Its software configuration.
传策薛
Contributor V
I also encountered the same problem, how can I configure pcie sata?
1074562799
Hi  Bio_Ticfsl,
      The i.MX8M has no support for SATA.  but  how can  i  config to  support sata. is  this have the illustrate  or  have a example  to configure.
      thanks
