iMX8M-Plus Supported Debugger for J-Tag
1,490 次查看
Awindbiker
Please guide with some list of suitable debugger for iMX8M-Plus to use J-Tag. Currently I am having J-Link Segger Plus which is not working with the same.
1,452 次查看
Awindbiker
Thanks for your Comment and Suggestion. I tried the above method and getting below attached error:
1.) Error While using J-Link Segger Commander tool to detect the IMX8M:
2.) Error while using VS Code with J-Link Extension and SDK Downloaded:
Also, I copied J-Link Patch file at following location:
Below is the attached Schematic for our Custom Dev Board for J-Tag:
1,474 次查看
Chavira
Hi @Awindbiker!
Thank you for contacting NXP Support!
The J link Segger Plus is compatible with iMX8MP.
Check this Application Note to see how to use the J Link Segger Plus on iMX8MP-EVK.
https://docs.nxp.com/bundle/AN14120/page/topics/introduction.html
Best Regards!
Chavira
