iMX8M KPP interface
iMX8M KPP interface
2,539 次查看
PaulW43
Although the IMX8MDQLQRM.pdf document references KPP signals (see p.1332 and screen grabs below) there are no other details that I can find in any other documentation to describe the interface specs or where to even access these signals (which pins).  Furthermore, I can't find anything anywhere online that describes anyone ever using the KPP interface on iMX8.
Does a KPP / keypad interface exist on iMX8MQ?  If so, where can I find technical details for it's use?
Thank you,
Paul W.
2,518 次查看
jimmychan
No, there is no KPP in i.MX8M.
2,519 次查看
jimmychan
2,515 次查看
PaulW43
Thank you very much.
2,528 次查看
KalaimaniArumugamdev
Hi @PaulW43
      For KPP technical information you can refer this.
