iMX7D RGMII DDR_SEL = (11)b Where could i find this parameter in the reference manual?
1,116 次查看
elena_faventi1
i.MX 7Dual Family
In the i.MX7Dual Family data sheet (IMX7DCEC.pdf Rev.6) Table 71. RGMII signal switching specifications1, it says the DDR_SEL field should be '11' for RGMII. Looking for this in the reference manual I have not been able to find it. Could this setting not exist in i.MX7D?
Thank you in advance
标记 (3)
1,109 次查看
Yuri
@elena_faventi1
   RGMII DDR_SEL parameter should be considered as a misprint for i.MX7.
It is actual for i.MX6.
Yuri.
1,100 次查看
elena_faventi1
OK, thank you!
1,110 次查看
Yuri
@elena_faventi1
Yuri.
