The title is the same as the question posted by cyuk on 09-07-2017, but the phenomenon in my case is different.
A parallel NOR flash is used as the boot element. I am debugging IVT using Segger's J-Link + J-FLash.
At first I was able to connect, but as I poceeded to change the IVT, the message "Failed to temporarily halting CPU for reading CP15 registers" appeared and I was unable to connect.
Is there a way to improve it ?
Best regards.
Solved! Go to Solution.
Similar questions have been asked by manufacturers other than NXP.
In conclusion, I found that this error occurs when the voltage somewhere in the circuit is not normal.
I resolved the error by checking all voltagfes on the circuit.
