iMX6ULZ datasheet does not define the SDIO version supported, what is the iMX6ULZ SDIO version? Some WiFi modules use SDIO version 3, can it be supported?
Thank you.
Kind regards,
jupiter
Is it correct that the iMX6ULZ SDIO is a standard protocol which is able to connect to any WiFi SDIO?
If it is correct, can iMX6ULZ also connect to SDIO version 3?
Thank you very much.
Kind regards,
jh
Yes, you can it in the RM, The features of the uSDHC module include Compatible with the SDIO Card Specification version 3.0.
I will help confirm and then give you update
