iMX6Q Android 4.4.3 use ov3640 image Grid problem
946 次查看
caritzhu
I use the android 4.4.3 BSP from freescale official website, and I port the ov3640 driver from ov5640 driver. I use 640*480 15pts for preview but 2048*1536 30pts for capture. The android system can preview the image correct but capture image is not good, the image has Grid problem. How can I solve this problem or ov3640 is not suitable for android application?
标签 (2)
674 次查看
jimmychan
please check the logcat that the Android select the correct resolution mode in your ov3640 driver.
For your reference:
Porting ov5645 to android jb4.2.2
674 次查看
caritzhu
Thanks!
I have confirmed the selection is correct. I use 640*480 15pts for preview but 2048*1536 15pts(i have written wrong for this framerate in the answer). I check in the logcat and console print. The ov3640 has two work mode: one is QXGA mode for full pixel and 15 framerate, the other is XGA mode for 1048*768 and 30 framerate. I only use QXGA mode for preview and capture, in order to avoid mode switch. I just set the register of crop, zoom and output size for the resolution mode changement. Is this correct?
