iMX6DL MMU setup
iMX6DL MMU setup
1,286 次查看
mjrudy
Hello I've starting working with the IMX6 dual lite board. My company runs all our applications with a bare metal implementation. I've gotten both core running but core 1 is extremely slow due to MMU not being set up. If I just try and copy what was done with the single core the processor crashes or I get undefined behavior. Does anyone know how to correctly setup the memory to separate core 0 from core 1 and also have a shared memory region. We would need to run this in AMP implantation as well.
Thank you,
Micah
1,280 次查看
