iMX6 Surround View Application EGL Issue
can_tuncbilek
I am trying to run a surround view demo app (surround-view-3D_1.1_beta) on I.MX6QP. There are some issues that I am facing:
  • Although successfully managed to build application from source code for X11, running app on the board gives Segmentation Fault with below trace ended with “rootwindow = RootWindow(eglNativeDisplayType, screen);”
#0  MyDisplay::dispInit (this=this@entry=0x13319f8) at ../Common/src/backend/x11/display.cpp:108
108     ../Common/src/backend/x11/display.cpp: No such file or directory.
(gdb)
(gdb) bt
#1  0x00019e58 in MyDisplay::MyDisplay (this=0x13319f8, keyboard_dev=<optimized out>, mouse_dev=<optimized out>)
    at ../Common/src/backend/x11/display.cpp:50
#2  0x00033090 in objectsInit () at src/auto_calib.cpp:178
#3  0x00014590 in main (argc=<optimized out>, argv=<optimized out>) at src/auto_calib.cpp:74
  •  When compiling demo app for fb, it gives following errors;
App/Source/Calibration/../Common/src/backend/fb/display.cpp:119: undefined reference to `fbGetDisplayByIndex'
App/Source/Calibration/../Common/src/backend/fb/display.cpp:129: undefined reference to `fbCreateWindow' collect2: error: ld returned 1 exit status
  How can I fix these problems? Is there any document or code except NXP Semiconductors Reference Manual and User’s Guide?
Labels (2)
Bio_TICFSL
Hello Can,
Segmentation fault comes with memory problem or it is full image in your board, please check it with DDR stress tool:
https://community.nxp.com/docs/DOC-105652
