iMX6 SSH error
iMX6 SSH error
1,507 次查看
lydiaj5000
I'm following NXP's white paper and trying to set-up Eclipse to work with an i.MX6 EVK running Yocto. Unfortunately, I get the following error when trying to connect via SSH: could not open connection algorithm negotiation failed. I can connect via Tera Term.
The white paper is pretty vague to say the least. Can anyone tell me what the issue is and how to fix it?
1,494 次查看
Zhiming_Liu
