iMX53 build errors
iMX53 build errors
1,700 次查看
AshokAiyawar
uccess: Now you can build android code for FSL i.MX platform
$ ./build_android.sh imx53_qsb all
Building:
BUILD_UBOOT=1
BUILD_KERNEL=1
BUILD_ANDROID=1
Using:
CPUS=4
CPUS_ANDROID=1
./build_android.sh: 164: make: not found
./build_android.sh: 181: make: not found
./build_android.sh: 193: make: not found
/home/ashokaiyawar/Downloads/Android3.3/i.MX53-QSB-Android-Release3.3/src/kernel_imx
cd: 203: can't cd to /home/ashokaiyawar/Downloads/Android3.3/i.MX53-QSB-Android-Release3.3/scripts/../src/out/target/product/imx53_loco.
Please help
标记 (1)
1 回复
1,645 次查看
VikramU_ng
Hi Ashok.
  Check your folder structure and permissions
run a make from the actual folder after checking if a .configure file is present on that folder path.
Make sure you clean and parameterize the folder paths %HOME%, %ANDROID% in future.
