iMX53 User Defined Button
893 次查看
AOlvera
I see on the schematic that SW4 and SW5 are buttons that are meant to be reprogrammed by the user. However I am having trouble finding documentation or example code of how this can be done. Ideally I would want to read the state of a button and light up an on-board LED when the button is pressed. Could someone please assist me in accomplishing this?
853 次查看
Rita_Wang
Which board are you using? NXP i.MX53 QSB Board? If yes, I will confirm it for you, as it is too old product.
