iMX53 Linux: tilt sensor/accelerometer
1,520 次查看
SimonasL_
In Xorg I see mouse pointer reset to centre whenever I tilt the board (as I tilt it more, it rotates) - clearly the accelerometer node is being picked up as a (mouse) input device -- how could I decouple and fix this?
Thank you in advance,
Simonas
标记 (1)
1 回复
1,390 次查看
KrishnaPavan
Fresh Out Contributor
Hi Simonas,
You can include automount rules in your config.
Try it, I am not completely sure, as I have worked with the USB only, it worked for me somehow.
