iMX27 rev 2.0
iMX27 rev 2.0
6,089 次查看
aurelihein
Does anybody have use the iMX27 ADS board revision 2 ?
I would like to know what are the difference between the rev 1 and the rev 2.0
I heard about clock . . .
I have some problems with the VPU and alsa, i tried the bluewind application from http://fs.bluewind.it , it's working but the video is very bad...
Thank you all,
aurelien
4 回复数
3,842 次查看
aurelihein
Oh, I was speaking about the chip revision . . . the iMX27 revision 2 and not about the demoboard
:smileywink:
I finally found out that they change their BIT processor firmware !!!
aurelien
3,842 次查看
arthas
thanks :smileywink:
3,842 次查看
arthas
Do you have some VPU test applications?
3,842 次查看
arthas
I'm working on rev 2.5!
and  have don't found problem !
