i.mx8mp reduce current consumption
1,361 次查看
junya
Hi NXP.
I want to reduce the current consumption to suppress heat generation on the i.MX8MP. However, for certain reasons, I need something that can be executed from the Linux command line.
Please tell me items that can be executed from the command line, will not cause malfunction, and are likely to be effective.
What I have tried so far is the method of stopping cores. Out of the four cores, I stopped three, but the utilization of the remaining core increased, and as a result, the current consumption did not change. (It’s possible that my method was incorrect.)
Thank you in advance.
1 回复
1,312 次查看
Rita_Wang
Hi @junya  Happy new 2026. You can follow the i.MX 8M Plus Power Consumption Measurement we supply:
Here I also attach it to you.
Hope can do help for you
Wish you have a nice day
Best Regards
Rita
