i.mx8mm sai1 to be configed for 64mic sampling
Search instead for
jimmyli
      We are trying to config sai1 to sample 64mic audio data, but fail.
      1>each sai-rx interface connects 2 codecs, each codec connects 4 mics.
      2>using sai1 rx0-rx7, total 8 ports with TDM mode, to sample 64mic.
      3>using tinycap tool to sample, but is failed and showed below:
          64mic: ./tinycap rec.wav -D 0 -d 0 -c 64 -r 48000 -b 32 -p 384 -n 4
          32mic: ./tinycap rec.wav -D 1 -d 0 -c 32 -r 48000 -b 32 -p 384 -n 4
     Can you help us to fix this problem?
     Thanks very much.
Linux ver: L5.4.47-2.2.0
b45499
Does it work well now?
jimmyli
    Sorry for replying too late.
    We can't still solve this problem, and hope you can provide some advises or example code.
     Thanks a lot.
