Target environment is Android 4.4.2 .
I installed UART2,3 with tested i.mx6Q quad processor without problem.
device is /dev/ttymx1, /dev/ttymx2
But processor MCimx6U5DVM10AC board can not run UART 2, 3 .
So question is I.mx6DL processor UART port has difference with Quad processor?
thanks for your response.
it was corrected by port pin mapping change.
Hi IS
DL has different than DQ registers addresses, also suggest to
look at attached Porting Guide Chapter 3 Registering a New UART Driver
