i.mx6 SoloLite BSP
i.mx6 SoloLite BSP
xiaojunqin
Dear NXP:
   We are now doing evaluation for a Eink project. AP will use i.mx6 SoloLite, would you please give us a link to get the chipset BSP, and  share us some guide document for display porting.
thanks.
BR.
gusarambula
Hello Xiaojun Qin,
The Linux BSPs available for the i.MX6SL can be found on the following link, please look for the Documentation Bundle of the BSP you are interested in:
https://www.nxp.com/support/developer-resources/run-time-software/linux-software-and-development-too...
As part of the documentation bundle you will find the Yocto Project User’s Guide, which includes instructions on how to build an image for the i.MX6SL.
As part of the documentation you will see also information on how to enable the EPDC inside the documentation. This is to support the NXP EBOOK module for the i.MX6SL (IMXEBOOKDC3-E). If you will be using your own eInk panel you should contact the manufacturer for the timing information and waveform, and have this information parsed for the i.MX6SL, which you can do by opening a Support Case.
I hope this helps,
