i.MX95: EdgeLock Enclave Key Import Error - SAB CMD [0x47] Resp [0x1829] (Invalid Signature)
1,496件の閲覧回数
Ankit_Agrawal
Hi Team,
We are currently working on importing a private key to an i.MX95 device following the guidelines in application note AN14898.
Environment & References:
Activities Completed So Far:
  1. Installed Python, pip, and the SPSDK toolset.
  2. Successfully built both the Host and Device applications.
  3. Copied device/bin/ele_key_import and device/scripts/run_test_on_board.sh to our target i.MX95 hardware.
  4. Executed the device-side flow to generate nxp_prod_ka_puk.bin.
  5. Transferred nxp_prod_ka_puk.bin back to our host environment.
  6. Generated SRK keys (secp384r1) using the SPSDK utility according to the SPSDK Documentation since we do not have final production keys yet.
  7. Generated the signed_msg.bin on the host side using the standard key import template (with the -k parameter set to secp384r1).
  8. Transferred the generated signed_msg.bin to the i.MX95 hardware.
    Command used to generate signed message:
    nxpimage signed-msg export -c key_exchange_temp.yaml -w assets
    Attached key_exchange_temp.yaml for reference.
  9. When running run_test_on_board.sh on the i.MX95 target device, all files are found, but the EdgeLock Enclave rejects the signature on the signed message block.Here is our target terminal log:
    nxp_prod_ka_puk.bin exists.
    oem_public_key.pem exists.
    signed_msg.bin exists.
    Hello, World! Jul 16 2026:06:54:40 9547bbd
    Signed Message: 728 bytes
    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
    OEM Import PUK: 65 bytes
    0451c46d24d30864c5275c634a3a339949654b34c0a4f294a8c107c504360ff4b55044918b71b16109a7bbfba8fbcf49b91720ad8e9c0109e6b2eed8f6a504ab64
    hsm_open_session success
    hsm_open_key_store_service success
    hsm_open_key_management_service success
    SAB Error: SAB CMD [0x47] Resp [0x1829] - Invalid Signature in SIGNED message.
    hsm_key_exchange failed err:0xfe
    Key exchange failed: 254
    Any insight on resolving this signature verification issue for the i.MX95 would be greatly appreciated.
    Ankit Agrawal
19 返答(返信)
1,055件の閲覧回数
rakhyoung
@Jessie_Lee
It is reported that things are not working as shown below. Is it possible to get some support?
However, when I execute the command to perform the fuse operation, I encounter the error below.
I tried resetting the hardware too, but I'm still facing the same issue. Do you have any ideas on why this might be happening?
@Ankit_Agrawal
Feel free to provide additional explanation if necessary.
1,042件の閲覧回数
Jessie_Lee
from @Ankit_Agrawal  , there was fastboot entering issue.
@rakhyoung  Do you mean you are also having issue to enter fastboot ?
did you try to  below command..? that I shared.. above?  what is error when you try to below fastboot 0 at uboot stage?
step#1. when you boot device, stop at u-boot console , run
u-boot=> fastboot 0
BRs
jessie
1,018件の閲覧回数
Ankit_Agrawal
Hello @Jessie_Lee
Sorry for the delayed response.
I successfully managed to stop at the U-Boot console on the device side. However, when trying to fuse the key from the host side using the following command:
nxpele -f mimx9596 -p /dev/ttyUSB1 batch outputs/ahab_oem2_srk0_hash_nxpele.bcf
I encountered the following error:
Ankit
952件の閲覧回数
Jessie_Lee
HI @Ankit_Agrawal
Could you please share all step log from fastboot entering at uboot (console), execute spsdk by host side?
I believe you entered fastboot thru uboot. right?
please share all steps (fastboot entering, ahab event check , try to fuse.. etc on host side log).
It would be helpful to see all logs thru files not snapshot.
BRs
jessie
886件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
I checked with your BSP team and fastboot is removed from default u-boot.
So, you could not use fastboot mode directly to fuse SRK.
Instead of SPSDK tool for burning SRK, you could use one of below method. As I know your team already use fuse_access application to handle fuse access (read/write) at kernel level.  any method could be okay to burn your srk.
BRs
jessie
789件の閲覧回数
Ankit_Agrawal
Hi @Jessie_Lee ,
Thank you very much for your continued guidance and support as we navigate our integration.
We reviewed the proposed procedure and steps for the i.MX95 Secure Enclave, but because the suggested methods require pre-build or static configuration, they will not be feasible for our current architecture. Our implementation strictly requires provisioning and managing keys at run time.
Could you let us know if there is an alternative approach or a dedicated Runtime Import Key API available to meet our requirements?
For context, the Import Key API is mandatory for our implementation due to two specific use cases:
  • Runtime Certificate Installation: During the flow, the application receives an encrypted contract certificate and private key. After decrypting this on the application side, the private key must be dynamically imported or stored into the Secure environment at run time.
  • Testing and Validation: For our current development and verification phase, we need to inject existing, pre-generated test keys (such as Contract Certificates, and Root Certificate keys) into the application-side Secure environment to validate the end-to-end communication flow and message signatures.
We would appreciate your insights on how we can achieve this dynamic injection without a pre-build setup cycle.
Ankit
686件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
To move further about the way of key import feature, May I ask your current status? Does it work on your side now with our current method?
To review your request for changing the way of key import feature , we need to understand firstly Other end side environment.  could you help us to understand your side situation ?
We need to understand "end to end protection" is secure enough
For example,
* How other end generate this encrypted contract certificate and private key?
* Or How the encrypted key of the blob is generated in LG/GM side?
* Could you please provide GM spec or GM spec numbers on this part?
then we can understand your concept and discuss with our security core team to support such way.
BRs
Jessie
432件の閲覧回数
Ankit_Agrawal
Hello @Jessie_Lee ,
Thank you for the support.
By using the fuse_access method, I am now able to fuse the SRKH, and the key import was successful using the test keys, as shown in the logs. I have attached the logs for both the SRKH fusing and the key import results.
Could you please review them to confirm if everything looks correct?
And regarding the request for changing the way of key import feature,
@rakhyoung  will share the detailed requirement details.
427件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
It is good news that you could do key import.
your device logs seems to be okay for key import except rsa4k case.
Didn't you send tlv_blob_rsa4k.bin from host to device? If you follow our script exactly, you may should have rsa4k.bin also .  please check below  part of device log  on our EVK(4k case).
For your reference, attached file is host side log(including generation tlv_blob_rsa4k.bin)  . please check with your host side log together.
BRs
jessie
424件の閲覧回数
Ankit_Agrawal
Hello @Jessie_Lee ,
Yes, I missed pushing the tlv_blob_rsa4k.bin file earlier. I have now pushed it and executed the process again, and I can see that all four keys have been imported successfully. I am attaching the complete logs for your reference.
Ankit
タグ(1)
418件の閲覧回数
Jessie_Lee
HI @Ankit_Agrawal
Okay, then, key import is okay now.
Let us wait the detail GM's scenario for reviewing other way of key import.
BRs
jessie
945件の閲覧回数
Ankit_Agrawal
Hello @Jessie_Lee ,
Please find attached logs for the fastboot entry, the host-side steps to check events and fuses, and the debug log file.
Ankit
943件の閲覧回数
Jessie_Lee
HI @Ankit_Agrawal
From your attached log, I could not find A core's uboot console log. (target board) when you enter fastboot on uboot console,   Could you please check this? Please share full uboot log from POR
 it seems that SPSDK detect uboot console by "=>" character.
What's your boot delay value(check by uboot command "printenv bootdelay")? Or can you add the bootdelay with uboot command "setenv bootdelay 3; saveenv" and try again?
BRs
jessie
933件の閲覧回数
Ankit_Agrawal
Hello @Jessie_Lee ,
Please find the attached logs. I have performed the steps as suggested by you.
913件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
I am wondering if you check your uboot log for fastboot entering .
Below is part of your log  and it show "unknown command" log. this fastboot is u-boot community feature which NXP's BSP also has but not in your SW env.
You need to discuss with your BSP team if BSP team remove this function.
BTW, NXP shared Updated ELE/V2X FW recently but your FW seems to be not latest.
Please discuss with your security internal team to sync up the FW version.  (btw, this FW version is not related with fastboot feature enablement or not)
BRs
jessie
BRs
jessie
1,469件の閲覧回数
Richard_Kim
Hello @Ankit_Agrawal,
Our internal team is reviewing your issue and will update you accordingly.
In the meantime, please review the case below, which is similar to the issue you are encountering.
The suggested solution is to verify that the fuse_version matches correctly.
https://community.nxp.com/t5/i-MX-Processors/hsm-import-key-returns-with-0xF0-Bad-Signature/td-p/216...
Thank you.
Richard
1,466件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
I am wondering if you burn SRKH  after SRK generation.  for necessary sign.yaml file please check my attached file.
Please try below command (precondition is you should have flash.bin: bootloader of system) to generate SRKH.
nxpimage ahab sign -c sign.yaml -b flash.bin -o flash_directsign.bin -fs outputs
output will be as below.
and from the ouputs folder, you could see bcf file(ahab_oem0_srk0_hash_nxpele.bcf).
you could follow below fuse command  (index 128 ~143) that you need to fuse for SRKH.
# nxpele AHAB SRKH fuses programming script
# Generated by SPSDK 3.4.0
# Family: mimx9596, Revision: latest
# Value: 0xCCC0605919B6400771CF88A002FB6BF27DFA9CE09BAD94516DD7E4D399369A8FF5A6A1A671809DF4A71A7CB208B4EDC009CDF3FF25EC074DECBBEE8300D5D44C
# Description: SHA512 hash digest of hash of four SRK keys
# Grouped register name: SRKH
# OTP ID: OEM_SRKH0, Value: 0x5960C0CC
write-fuse --index 128 --data 0x5960C0CC
# OTP ID: OEM_SRKH1, Value: 0x0740B619
write-fuse --index 129 --data 0x740B619
# OTP ID: OEM_SRKH2, Value: 0xA088CF71
write-fuse --index 130 --data 0xA088CF71
# OTP ID: OEM_SRKH3, Value: 0xF26BFB02
write-fuse --index 131 --data 0xF26BFB02
# OTP ID: OEM_SRKH4, Value: 0xE09CFA7D
write-fuse --index 132 --data 0xE09CFA7D
# OTP ID: OEM_SRKH5, Value: 0x5194AD9B
write-fuse --index 133 --data 0x5194AD9B
# OTP ID: OEM_SRKH6, Value: 0xD3E4D76D
write-fuse --index 134 --data 0xD3E4D76D
# OTP ID: OEM_SRKH7, Value: 0x8F9A3699
write-fuse --index 135 --data 0x8F9A3699
# OTP ID: OEM_SRKH8, Value: 0xA6A1A6F5
write-fuse --index 136 --data 0xA6A1A6F5
# OTP ID: OEM_SRKH9, Value: 0xF49D8071
write-fuse --index 137 --data 0xF49D8071
# OTP ID: OEM_SRKH10, Value: 0xB27C1AA7
write-fuse --index 138 --data 0xB27C1AA7
# OTP ID: OEM_SRKH11, Value: 0xC0EDB408
write-fuse --index 139 --data 0xC0EDB408
# OTP ID: OEM_SRKH12, Value: 0xFFF3CD09
write-fuse --index 140 --data 0xFFF3CD09
# OTP ID: OEM_SRKH13, Value: 0x4D07EC25
write-fuse --index 141 --data 0x4D07EC25
# OTP ID: OEM_SRKH14, Value: 0x83EEBBEC
write-fuse --index 142 --data 0x83EEBBEC
# OTP ID: OEM_SRKH15, Value: 0x4CD4D500
write-fuse --index 143 --data 0x4CD4D500
you could use below command to burn SRKH
nxpele -f mimx9596 batch outputs\ahab_oem0_srk0_hash_nxpele.bcf
If you burn the SRKH already but failed with below invalid singing, please share the singed_message.bin to us.  with your SRKH (including srk output all).
1,266件の閲覧回数
Ankit_Agrawal
Hi @Jessie_Lee ,
Thanks for the information.
We have located the flash.bin file and are able to perform the necessary steps to generate the SRKH.
After generating the SRKH, we need to fuse it to the hardware. To perform the fuse operation, the hardware/board must be in Fastboot mode. Could you please help us switch the device to Fastboot mode?
While attempting to fuse the keys, we are encountering the following error:
It appears that the device is not currently in Fastboot mode. Any guidance on how to enable Fastboot mode on the board would be greatly appreciated.
Ankit
1,257件の閲覧回数
Jessie_Lee
Hi @Ankit_Agrawal
Please follow up below steps to burn SRK using SPSDK
u-boot=> fastboot 0
step#2.  In SPSDK console , you must there is no ahab events) using below command.
nxpele -f mimx9596 get-events
step#3. If there is no event,  you could burn SRK key now in SPSDK console.
nxpele -f mimx9596 batch outputs\ahab_oem2_srk0_hash_nxpele.bcf
BRs
jessie
%3CLINGO-SUB%20id%3D%22lingo-sub-2405146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX95%3A%20EdgeLock%20Enclave%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(%E7%84%A1%E5%8A%B9%E3%81%AA%E7%BD%B2%E5%90%8D)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%3CSTRONG%3E%20AN14898%3C%2FSTRONG%3E%20%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%20%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Fsearch%3Fibp%3Doshop%26amp%3Bprds%3Dpvt%3Ahg%2Cpvo%3A29%2CimageDocid%3A10454109626952377055%2CheadlineOfferDocid%3A16942149593012699800%2CproductDocid%3A16942149593012699800%26amp%3Bq%3Dproduct%26amp%3Bsa%3DX%26amp%3Bved%3D2ahUKEwjCpfTLwJ-WAxW5m-EIHYlGM_cQxa4PegYIAAgPEAE%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX95%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E7%A7%98%E5%AF%86%E9%8D%B5%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E4%BD%9C%E6%A5%AD%E3%82%92%E9%80%B2%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%E7%92%B0%E5%A2%83%E3%81%A8%E5%8F%82%E8%80%83%E6%96%87%E7%8C%AE%3A%3C%2FSTRONG%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E5%AF%BE%E8%B1%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Fsearch%3Fibp%3Doshop%26amp%3Bprds%3Dpvt%3Ahg%2Cpvo%3A29%2CimageDocid%3A10454109626952377055%2CheadlineOfferDocid%3A16942149593012699800%2CproductDocid%3A16942149593012699800%26amp%3Bq%3Dproduct%26amp%3Bsa%3DX%26amp%3Bved%3D2ahUKEwjCpfTLwJ-WAxW5m-EIHYlGM_cQxa4PegYIAAgREAM%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX95%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3A%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3DCAESUgHuR6pNa-EbAS1iH71iTgn4T9F2guNuMAxogsURan4yjzrB1gZSke31V576eb41E5BUnnTw7K4fpEpVcqz9ye_p14WDwPK3Sgo3P439I4b-1l0%253D%26amp%3Buoh%3D2%26amp%3Bved%3D2ahUKEwjCpfTLwJ-WAxW5m-EIHYlGM_cQy_kOegYIAAgREAU%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw0sojBqG5zQSjPkioZOx9Rr%26amp%3Bust%3D1786775774500000%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Eimx_sec_apps%2Fimx-ele-apps%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3ESPSDK%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%9A%3C%2FSTRONG%3E%E6%9C%80%E6%96%B0%E3%81%AE%E6%A8%99%E6%BA%96%E3%83%84%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E6%B4%BB%E5%8B%95%3A%3C%2FSTRONG%3E%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EPython%E3%80%81pip%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3SPSDK%E3%83%84%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%84%A1%E4%BA%8B%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Edevice%2Fbin%2Fele_key_import%20%E3%81%A8%20device%2Fscripts%2Frun_test_on_board.sh%20%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Fsearch%3Fibp%3Doshop%26amp%3Bprds%3Dpvt%3Ahg%2Cpvo%3A29%2CimageDocid%3A17964331766201285693%2CheadlineOfferDocid%3A12207024310313732767%2CproductDocid%3A12207024310313732767%26amp%3Bq%3Dproduct%26amp%3Bsa%3DX%26amp%3Bved%3D2ahUKEwjCpfTLwJ-WAxW5m-EIHYlGM_cQxa4PegYIAAgVEAM%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX95%3C%2FA%3E%3C%2FSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%81%B4%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81nxp_prod_ka_puk.bin%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Enxp_prod_ka_puk.bin%E3%82%92%E3%83%9B%E3%82%B9%E3%83%88%E7%92%B0%E5%A2%83%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E7%94%9F%E7%94%A3%E3%82%AD%E3%83%BC%E3%81%8C%E3%81%BE%E3%81%A0%E6%89%8B%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81SPSDK%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8SPSDK%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6SRK%E3%82%AD%E3%83%BC(secp384r1)%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%A7%E6%A8%99%E6%BA%96%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%88-k%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92secp384r1%E3%81%AB%E8%A8%AD%E5%AE%9A%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6signed_msg.bin%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9Fsigned_msg.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Fsearch%3Fibp%3Doshop%26amp%3Bprds%3Dpvt%3Ahg%2Cpvo%3A29%2CimageDocid%3A17964331766201285693%2CheadlineOfferDocid%3A12207024310313732767%2CproductDocid%3A12207024310313732767%26amp%3Bq%3Dproduct%26amp%3Bsa%3DX%26amp%3Bved%3D2ahUKEwjCpfTLwJ-WAxW5m-EIHYlGM_cQxa4PegYIAAgVEAk%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX95%3C%2FA%3E%3C%2FSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E7%BD%B2%E5%90%8D%E4%BB%98%E3%81%8D%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%9A%3CBR%20%2F%3E%20%3CSTRONG%3Enxpimage%20signed-msg%20export%20-c%20key_exchange_temp.yaml%20-w%20assets%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81key_exchange_temp.yaml%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3Ei.MX95%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7run_test_on_board.sh%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81EdgeLock%20Enclave%E3%81%8C%E7%BD%B2%E5%90%8D%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E7%BD%B2%E5%90%8D%E3%82%92%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E7%AB%AF%E6%9C%AB%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20color%3D%22%23FF9900%22%3Enxp_prod_ka_puk.bin%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3Eoem_public_key.pem%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3Esigned_msg.bin%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E4%B8%96%E7%95%8C%EF%BC%81%202026%E5%B9%B47%E6%9C%8816%E6%97%A5%2006%3A54%3A40%209547bbd%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3E%E7%BD%B2%E5%90%8D%E4%BB%98%E3%81%8D%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%EF%BC%9A728%E3%83%90%E3%82%A4%E3%83%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%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%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF9900%22%3EOEM%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88PUK%EF%BC%9A65%E3%83%90%E3%82%A4%E3%83%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3E0451c46d24d30864c5275c634a3a339949654b34c0a4f294a8c107c504360ff4b%2055044918b71b16109a7bbfba8fbcf49b91720ad8e9c0109e6b2eed8f6a504ab64%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF9900%22%3Ehsm_open_session%20%E6%88%90%E5%8A%9F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3Ehsm_open_key_store_service%20%E6%88%90%E5%8A%9F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3Ehsm_open_key_management_service%20%E6%88%90%E5%8A%9F%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF9900%22%3ESAB%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20-%20SIGNED%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E7%BD%B2%E5%90%8D%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF9900%22%3Ehsm_key_exchange%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0xfe%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3E%E9%8D%B5%E4%BA%A4%E6%8F%9B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20254%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20i.MX95%E3%81%AE%E7%BD%B2%E5%90%8D%E6%A4%9C%E8%A8%BC%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%9C%E3%81%B2%E3%81%94%E6%95%99%E7%A4%BA%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%E3%83%BB%E3%82%A2%E3%82%B0%E3%83%A9%E3%83%AF%E3%83%AB%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ESRK%E7%94%9F%E6%88%90%E5%BE%8C%E3%81%ABSRKH%E3%82%92%E7%84%BC%E5%8D%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AAsign.yaml%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%A8%E3%81%97%E3%81%A6flash.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SRKH%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%3CSTRONG%3Enxpimage%20ahab%20sign%20-c%20sign.yaml%20-b%20flash.bin%20-o%20flash_directsign.bin%20-fs%20%E5%87%BA%E5%8A%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E5%87%BA%E5%8A%9B%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1786699088609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394634i183A58F59E3D03AE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jessie_Lee_0-1786699088609.png%22%20alt%3D%22Jessie_Lee_0-1786699088609.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1786699088609.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6Ouputs%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E3%81%AFbcf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(ahab_oem0_srk0_hash_nxpele.bcf)%E3%81%8C%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E3%81%AE%E3%83%95%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9128~143)%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81SRKH%E3%81%A7%E3%83%95%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CEM%3E%23%20nxpele%20AHAB%20SRKH%20%E3%81%8C%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E8%9E%8D%E5%90%88%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23%20SPSDK%203.4.0%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3A%20mimx9596%2C%20Revision%3A%20latest%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%23%20%E5%80%A4%3A%200xCCC0605919B6400771CF88A002FB6BF27DFA9CE09BAD94516DD7E4D399369A8FF5A6A1A671809DF4A71A7CB208B4EDC009CDF3FF25EC074DECBBEE8300D5D44C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20%E8%AA%AC%E6%98%8E%3A%204%20%E3%81%A4%E3%81%AE%20SRK%20%E3%82%AD%E3%83%BC%E3%81%AE%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%20SHA512%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%80%E3%82%A4%E3%82%B8%E3%82%A7%E3%82%B9%E3%83%88%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%90%8D%3A%20SRKH%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH0%E3%80%81%E5%80%A4%3A%200x5960C0CC%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3Ewrite-fuse%20--index%20128%20--data%200x5960C0CC%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH1%E3%80%81%E5%80%A4%3A%200x0740B619%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3Ewrite-fuse%20--index%20129%20--data%200x740B619%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH2%E3%80%81%E5%80%A4%3A%200xA088CF71%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20130%20--data%200xA088CF71%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH3%E3%80%81%E5%80%A4%3A%200xF26BFB02%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20131%20--data%200xF26BFB02%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH4%E3%80%81%E5%80%A4%3A%200xE09CFA7D%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20132%20--data%200xE09CFA7D%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH5%E3%80%81%E5%80%A4%3A%200x5194AD9B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20133%20--data%200x5194AD9B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH6%E3%80%81%E5%80%A4%3A%200xD3E4D76D%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20134%20--data%200xD3E4D76D%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH7%E3%80%81%E5%80%A4%3A%200x8F9A3699%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20135%20--data%200x8F9A3699%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH8%E3%80%81%E5%80%A4%3A%200xA6A1A6F5%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20136%20--data%200xA6A1A6F5%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH9%E3%80%81%E5%80%A4%3A%200xF49D8071%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20137%20--data%200xF49D8071%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH10%E3%80%81%E5%80%A4%3A%200xB27C1AA7%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20138%20--data%200xB27C1AA7%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH11%E3%80%81%E5%80%A4%3A%200xC0EDB408%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20139%20--data%200xC0EDB408%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH12%E3%80%81%E5%80%A4%3A%200xFFF3CD09%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20140%20--data%200xFFF3CD09%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH13%E3%80%81%E5%80%A4%3A%200x4D07EC25%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20141%20--data%200x4D07EC25%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH14%E3%80%81%E5%80%A4%3A%200x83EEBBEC%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20142%20--data%200x83EEBBEC%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23%20OTP%20ID%3A%20OEM_SRKH15%E3%80%81%E5%80%A4%3A%200x4CD4D500%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Ewrite-fuse%20--index%20143%20--data%200x4CD4D500%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EBelow%20Command%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6SRKH%E3%82%92%E7%84%BC%E3%81%8F%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3Enxpele%20-f%20mimx9596%20%E3%83%90%E3%83%83%E3%83%81%E5%87%BA%E5%8A%9B%5Cahab_oem0_srk0_hash_nxpele.bcf%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%97%A2%E3%81%ABSRKH%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A0%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E4%B8%8B%E8%A8%98%E3%81%AE%E7%84%A1%E5%8A%B9%E3%81%AA%E7%BD%B2%E5%90%8D%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81singed_message.bin%E3%81%A8SRKH%EF%BC%88srk%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%82%92%E5%BC%8A%E7%A4%BE%E3%81%BE%E3%81%A7%E3%81%8A%E9%80%81%E3%82%8A%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%E7%A4%BE%E5%86%85%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%80%B2%E6%8D%97%E7%8A%B6%E6%B3%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E8%BF%BD%E3%81%A3%E3%81%A6%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E9%96%93%E3%81%AB%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A8%E4%BC%BC%E3%81%9F%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E3%81%9C%E3%81%B2%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%20%3CSTRONG%3Efuse_version%E3%81%8C%3C%2FSTRONG%3E%E6%AD%A3%E3%81%97%E3%81%8F%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fhsm-import-key-returns-with-0xF0-Bad-Signature%2Ftd-p%2F2163777%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fhsm-import-key-returns-with-0xF0-Bad-Signature%2Ftd-p%2F2163777%3C%2FA%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3ESPSDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SRK%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%3C%2FSTRONG%3E%20%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%89%E3%80%81u-boot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3Eu-boot%3D%26gt%3B%20fastboot%200%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%3C%2FSTRONG%3E%20%E3%80%82SPSDK%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6ahab%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3ENXPELE%20-f%20mimx9596%20get-events%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%973%3C%2FSTRONG%3E%20%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E4%BB%8A%E3%81%99%E3%81%90SPSDK%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7SRK%E3%82%AD%E3%83%BC%E3%82%92%E7%84%BC%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSPAN%3Enxpele%20-f%20mimx9596%20%E3%83%90%E3%83%83%E3%83%81%E5%87%BA%E5%8A%9B%5Cahab_oem2_srk0_hash_nxpele.bcf%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSPAN%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%93%E3%83%B3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81SRKH%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESRKH%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E8%9E%8D%E5%90%88%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%2F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92Fastboot%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E8%9E%8D%E5%90%88%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%9F%E9%9A%9B%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395273i5339C853FDF13C46%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Ankit_Agrawal_0-1787636692485.png%22%20alt%3D%22Ankit_Agrawal_0-1787636692485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnkit_Agrawal_0-1787636692485.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%8F%BE%E5%9C%A8Fastboot%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7Fastboot%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E6%95%99%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8B%E8%A8%98%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E4%B8%8D%E5%85%B7%E5%90%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AE%E5%A0%B1%E5%91%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E--------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%82%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%93%E3%81%86%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rakhyoung_0-1789101296622.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396261iB193BE3690252F57%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rakhyoung_0-1789101296622.png%22%20alt%3D%22rakhyoung_0-1789101296622.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Erakhyoung_0-1789101296622.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%3C%2FA%3E%3CBR%20%2F%3E%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E9%81%A0%E6%85%AE%E3%81%AA%E3%81%8F%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%3C%2FA%3E%E3%81%95%E3%82%93%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81fastboot%20%E3%81%AB%E5%85%A5%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232008%22%20target%3D%22_blank%22%3E%40rakhyoung%3C%2FA%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%82%82fastboot%E3%81%AB%E5%85%A5%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9Fu-boot%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%A7fastboot%200%E3%82%88%E3%82%8A%E4%B8%8B%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3E%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%3C%2FSTRONG%3E%20%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%89%E3%80%81u-boot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%222%22%3Eu-boot%3D%26gt%3B%20fastboot%200%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%E3%81%95%E3%82%93%3C%2FA%3E%3CBR%20%2F%3E%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%81%B4%E3%81%AEU-Boot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%8B%E3%82%89%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%BC%E3%82%92%E8%9E%8D%E5%90%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3Enxpele%20-f%20mimx9596%20-p%20%2Fdev%2FttyUSB1%20batch%20outputs%2Fahab_oem2_srk0_hash_nxpele.bcf%3C%2FSTRONG%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396303i911174C3CDACCDC8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20alt%3D%22Screenshot%20from%202026-09-13%2021-29-30.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-13%2021-29-30.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2026-09-13%2021-29-30%20%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%82%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%93%E3%81%86%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%94%E6%8C%87%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Efastboot%E3%81%8B%E3%82%89uboot(%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB)%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%A7spsdk%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E5%85%A8%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFu-boot%E7%B5%8C%E7%94%B1%E3%81%A7fastboot%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8F%B3%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86(FastBoot%E3%81%AE%E5%85%A5%E3%82%8A%E3%80%81AHAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%80%81%E3%83%95%E3%83%A5%E3%83%BC%E3%82%BA%E8%A9%A6%E8%A1%8C%E3%81%AA%E3%81%A9)%E3%82%92%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%8A%E3%83%83%E3%83%97%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%80%9A%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3Efastboot%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3C%2FSTRONG%3E%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%84%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AE%E6%89%8B%E9%A0%86%E3%80%81%3CSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AD%E3%82%B0%3C%2FSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%AD%E3%82%B0%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E3%81%AF%E3%80%81A%E3%82%B3%E3%82%A2%E3%81%AEuboot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89)%3CSPAN%20data-teams%3D%22true%22%3Euboot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7fastboot%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%E3%81%8D%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3FPOR%E3%81%AEuboot%E3%83%AD%E3%82%B0%E5%85%A8%E6%96%87%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3ESPSDK%E3%81%AF%E3%80%8C%3D%26gt%3B%E3%80%8D%E6%96%87%E5%AD%97%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6U-Boot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%E5%80%A4%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%EF%BC%88uboot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Cprintenv%20bootdelay%E3%80%8D%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%EF%BC%89%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82uboot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Csetenv%20bootdelay%203%3Bsaveenv%E3%80%8D%E3%81%A7bootdelay%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Efastboot%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81uboot%20%E3%83%AD%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%83%AD%E3%82%B0%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%80%81%E3%80%8C%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AEfastboot%E3%81%AFU-Boot%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81NXP%E3%81%AEBSP%E3%81%AB%E3%82%82%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E7%92%B0%E5%A2%83%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EBSP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81BSP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E8%A9%B1%E3%81%97%E5%90%88%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81NXP%E3%81%AF%E6%9C%80%E8%BF%91ELE%2FV2X%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%85%AC%E9%96%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E6%9C%80%E6%96%B0%E7%89%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E5%86%85%E9%83%A8%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%97%E3%81%A6%E3%80%81FW%E7%89%88%E3%81%AE%E5%90%8C%E6%9C%9F%E3%82%92%E4%BE%9D%E9%A0%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82(%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E3%81%93%E3%81%AEFW%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFfastboot%E6%A9%9F%E8%83%BD%E3%81%AE%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789613044617.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396502iF4CD2A65E4FCFB43%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jessie_Lee_0-1789613044617.png%22%20alt%3D%22Jessie_Lee_0-1789613044617.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1789613044617.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1789613044617.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBSP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81fastboot%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEu-boot%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81fastboot%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E4%BD%BF%E3%81%A3%E3%81%A6SRK%E3%82%92%E8%9E%8D%E5%90%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3ESRK%E3%82%92%E7%87%83%E3%82%84%E3%81%99%E3%81%9F%E3%82%81%E3%81%AESPSDK%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%AE%E9%80%9A%E3%82%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E3%81%99%E3%81%A7%E3%81%ABfuse_access%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%95%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9(%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D)%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%82%93%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%82SRK%E3%82%92%E7%84%BC%E3%81%8F%E3%81%AE%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1789713874158.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396555iEE837BA135FA635E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jessie_Lee_0-1789713874158.png%22%20alt%3D%22Jessie_Lee_0-1789713874158.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJessie_Lee_0-1789713874158.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%E7%B5%B1%E5%90%88%E3%81%AB%E5%90%91%E3%81%91%E3%81%A6%3CSTRONG%3E%E3%80%81%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%A8%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FSTRONG%3E%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3Ei.MX95%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%82%A8%E3%83%B3%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%96%3C%2FSTRONG%3E%E3%81%AE%E6%8F%90%E6%A1%88%E6%89%8B%E9%A0%86%E3%81%A8%E6%89%8B%E9%A0%86%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B9%E6%B3%95%E3%81%AF%3CSTRONG%3E%E4%BA%8B%E5%89%8D%E6%A7%8B%E7%AF%89%E3%81%BE%E3%81%9F%E3%81%AF%E9%9D%99%E7%9A%84%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%8F%BE%E8%A1%8C%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%A7%E3%81%AF%E5%AE%9F%E7%8F%BE%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%AF%3CSTRONG%3E%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%3C%2FSTRONG%3E%E3%81%AB%E9%8D%B5%E3%82%92%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8A%E3%82%88%E3%81%B3%E7%AE%A1%E7%90%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%B3%E5%AF%86%E3%81%AB%E6%B1%82%E3%82%81%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E4%BB%A3%E6%9B%BF%E6%96%B9%E6%B3%95%E3%82%84%E5%B0%82%E7%94%A8%E3%81%AE%20%3CSTRONG%3E%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%AD%E3%83%BCAPI%3C%2FSTRONG%3E%20%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%20%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%AD%E3%83%BCAPI%3C%2FSTRONG%3E%20%E3%81%AF2%E3%81%A4%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%AB%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3A%3C%2FSTRONG%3E%20%E3%83%95%E3%83%AD%E3%83%BC%E4%B8%AD%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E5%A5%91%E7%B4%84%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%A8%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%81%B4%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E5%BE%A9%E5%8F%B7%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E7%A7%98%E5%AF%86%E9%8D%B5%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E5%8B%95%E7%9A%84%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E6%A4%9C%E8%A8%BC%3A%3C%2FSTRONG%3E%20%E7%8F%BE%E5%9C%A8%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E6%A4%9C%E8%A8%BC%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%81%AF%E3%80%81%E6%97%A2%E5%AD%98%E3%81%AE%E4%BA%8B%E5%89%8D%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%86%E3%82%B9%E3%83%88%E3%82%AD%E3%83%BC(%E5%A5%91%E7%B4%84%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%84%E3%83%AB%E3%83%BC%E3%83%88%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%AD%E3%83%BC%E3%81%AA%E3%81%A9)%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%81%B4%E3%81%AESecure%E7%92%B0%E5%A2%83%E3%81%AB%E6%B3%A8%E5%85%A5%E3%81%97%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%84%E3%83%BC%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E9%80%9A%E4%BF%A1%E3%83%95%E3%83%AD%E3%83%BC%E3%81%A8%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E7%BD%B2%E5%90%8D%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%E4%BA%8B%E5%89%8D%E6%A7%8B%E7%AF%89%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AA%E3%81%97%E3%81%A7%E3%81%93%E3%81%AE%E3%83%80%E3%82%A4%E3%83%8A%E3%83%9F%E3%83%83%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%A7%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%94%E6%84%8F%E8%A6%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E6%A9%9F%E8%83%BD%E3%81%AE%E5%AE%9F%E8%A3%85%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%8F%E3%81%8A%E4%BC%BA%E3%81%84%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%8A%B6%E6%B3%81%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E4%BB%8A%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A7%E3%82%82%E5%8A%B9%E6%9E%9C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E6%A9%9F%E8%83%BD%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E8%A6%81%E6%9C%9B%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%82%E3%81%9F%E3%82%8A%E3%80%81%E3%81%BE%E3%81%9A%E7%9B%B8%E6%89%8B%E5%81%B4%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E9%9D%A2%E3%81%AE%E7%8A%B6%E6%B3%81%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E6%89%8B%E5%8A%A9%E3%81%91%E3%82%92%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E3%82%A8%E3%83%B3%E3%83%89%E3%83%84%E3%83%BC%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E4%BF%9D%E8%AD%B7%E3%80%8D%E3%81%8C%E5%8D%81%E5%88%86%E3%81%AB%E5%AE%89%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%20%20%20%3C%2FP%3E%0A%3CP%3E*%20%E7%9B%B8%E6%89%8B%E5%81%B4%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E5%A5%91%E7%B4%84%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%A8%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E*%20%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81LG%2FGM%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%83%96%E3%83%AD%E3%83%96%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E*%20%E3%81%93%E3%81%AE%E9%83%A8%E5%93%81%E3%81%AEGM%E4%BB%95%E6%A7%98%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%95%E6%A7%98%E7%95%AA%E5%8F%B7%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3CSPAN%20data-teams%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BB%E3%83%97%E3%83%88%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%B3%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E5%8D%94%E8%AD%B0%E3%81%97%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20data-teams%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3CSPAN%20data-teams%3D%22true%22%3EBR%3C%2FSPAN%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3CSPAN%20data-teams%3D%22true%22%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FSPAN%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%81%97%E3%80%81%E3%82%AD%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EGM%E3%81%8C%E6%8F%90%E7%A4%BA%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%80%81%E9%8D%B5%E3%81%AE%E8%BC%B8%E5%85%A5%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265595%22%20target%3D%22_blank%22%3E%40Ankit_Agrawal%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%87%8D%E8%A6%81%E3%81%AA%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%81%AF%E8%89%AF%E3%81%84%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AF%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81RSA4K%20CASE%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jessie_Lee_0-1791361962981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1791361962981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1791361962981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_0-1791361962981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397404i9D2699B5A1AA2684%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Jessie_Lee_0-1791361962981.png%22%20alt%3D%22Jessie_Lee_0-1791361962981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%ABtlv_blob_rsa4k.bin%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81rsa4k.bin%E3%82%82%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E5%BD%93%E7%A4%BE%E3%81%AEEVK(4K%20CASE)%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AD%E3%82%B0%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jessie_Lee_1-1791362085066.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_1-1791362085066.png%22%20style%3D%22width%3A%20724px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_1-1791362085066.png%22%20style%3D%22width%3A%20724px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jessie_Lee_1-1791362085066.png%22%20style%3D%22width%3A%20724px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397405iD0E5CD54F4E7AF89%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Jessie_Lee_1-1791362085066.png%22%20alt%3D%22Jessie_Lee_1-1791362085066.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AE%E3%83%AD%E3%82%B0%EF%BC%88%E7%94%9F%E6%88%90%E6%99%82%E3%81%AEtlv_blob_rsa4k.bin%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%A7%E3%81%99%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%82%E4%BD%B5%E3%81%9B%E3%81%A6%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%E3%81%AF%E3%81%84%E3%80%81%E5%85%88%E3%81%BB%E3%81%A9tlv_blob_rsa4k.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E5%BA%A6%E3%81%AF%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%814%E3%81%A4%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E3%83%AD%E3%82%B0%E3%81%AE%E5%85%A8%E6%96%87%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Ankit_Agrawal_0-1791364405062.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1791364405062.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ankit_Agrawal_0-1791364405062.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397410i615E5DE5C2553AA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Ankit_Agrawal_0-1791364405062.png%22%20alt%3D%22Ankit_Agrawal_0-1791364405062.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX95%3A%20EdgeLock%20Enclave%20Key%20Import%20Error%20-%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20(Invalid%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59403%22%20target%3D%22_blank%22%3E%40Jessie_Lee%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3Ef%3CSTRONG%3E%20use_access%3C%2FSTRONG%3E%3CSPAN%3E%20%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%92%E7%94%A8%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%20SRKH%E3%82%92%E8%9E%8D%E5%90%88%E3%81%A7%E3%81%8D%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(%E3%83%AD%E3%82%B0%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82SRKH%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E6%A9%9F%E8%83%BD%E3%81%AE%E5%A4%89%E6%9B%B4%E8%A6%81%E8%AB%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232008%22%20target%3D%22_blank%22%3E%40rakhyoung%3C%2FA%3E%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%A6%81%E4%BB%B6%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
