i.MX8QXP MEK Board - differences between PCB rev C1 and C2 ?
2,574 次查看
LaurentBardet
Could you tell which are the differences between MEK board in revision C1 and revision C2 ?
Reason for this request : we (our organisation and one partner) are experiencing slightly behaviour differences between our respective boards, with the same uBoot. And the almost last remaining differences are MEK boards: both have B0 silicium, but their PCB differs (rev C1 vs. C2).
See attached file for detailed configuration of our respective boards.
Laurent
2,516 次查看
AldoG
Please take a look to the schematic page 2, there you'll find the revision notes for the board, you can download the document from here:
https://www.nxp.com/downloads/en/software/i.MX8QXPDF.zip
Also, please remember that the i.MX8X family is still in the pre-production stage so our support is limited, for further support please contact your assigned NXP FAE.
Thank you for your understanding,
Aldo
