Hello @Manuel_Salas
Yes, we're doing fine, thanks for asking!
Just to be sure we're aligned, we want to develop the software on the A-core, not on the M4 or even directly on the M0+ cores.
From what we've seen in the provided document, there should be a driver inside the Linux distribution, right? I think I've found the source code of this.
The firmware itself that must be loaded on these M0+ cores, is this also somewhere present inside the Linux distribution?
Many thanks again!
ToarteFretter.
