i.MX8Q Android How to enable SPDIF output
n3820fjmn2k2q
I'm using i.MX8QXP MEK CORE&BaseBoard.
As default, SPDIF output(imx-spdif) is not defined in dts file.
Can this board output SPDIF? and How to?
Hi Makoto
spdif is not supported according to Android Release Notes document included in
Android P9.0.0_1.0.0 Documentation
One can try modifications as in below dts example (check that spdif muxing options were
not affected by other modules)
linux/arch/arm64/boot/dts/freescale/fsl-imx8qxp-lpddr4-arm2-spdif.dts
fsl-imx8qxp-lpddr4-arm2-spdif.dts\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
Hi Makoto
n3820fjmn2k2q
Hi igor.
Ive refered to fsl-imx8qxp-lpddr4-arm2-spdif.dts and tried, but didnt work.
Thank you for your explanations.
relax-wu
Has your problem been solved? Can you share it?
