i.MX8MP gpio wakeup type issue
2,850 次查看
Winslow
I'm using imx8mp EVK Linux 6.12.3_1.0.0 and testing gpio wakeup
when setting IRQ_TYPE_EDGE_FALLING
The system is incorrectly woken up when the GPIO changes from low to high.
(It should be wakeup when GPIO changes from high to low only)
How can this problem be solved?
Thank you
11 回复数
2,820 次查看
Zhiming_Liu
Hi @Winslow
How do you configure the gpio wakeup in dts?
Here is drivers/input/keyboard/gpio_keys.c source code, you can try to dump
bdata->wakeup_trigger_type to confirm real type in driver.
bool active_low = gpiod_is_active_low(bdata->gpiod);
switch (button->wakeup_event_action) {
		case EV_ACT_ASSERTED:
			bdata->wakeup_trigger_type = active_low ?
				IRQ_TYPE_EDGE_FALLING : IRQ_TYPE_EDGE_RISING;
			break;
		case EV_ACT_DEASSERTED:
				IRQ_TYPE_EDGE_RISING : IRQ_TYPE_EDGE_FALLING;
			break;
		case EV_ACT_ANY:
Zhiming
2,811 次查看
Winslow
Hi @Zhiming_Liu
my setting is
        btn-wakeup {
            label = "BTN-WAKEUP";
            gpios = <&gpio5 12 GPIO_ACTIVE_LOW>;
            linux,code = <KEY_WAKEUP>;
            debounce-interval = <10>;
            interrupt-parent = <&gpio5>;
            interrupts = <12 IRQ_TYPE_EDGE_FALLING>;
            wakeup-source;
Does this code means irq is setting trigger both falling and rising?
irqflags = IRQF_TRIGGER_RISING | IRQF_TRIGGER_FALLING;
error = devm_request_any_context_irq(dev, bdata->irq, isr, irqflags,
desc, bdata);
2,801 次查看
Zhiming_Liu
Hi @Winslow
Did you set the pull up in iomux setting? and make sure that this gpio stay high before your click the button. Otherwise, there is no HIGH->LOW signal when you click button. If this gpio stays low before you click the button, the driver's action is correct.
Zhiming
2,796 次查看
Winslow
Hi @Zhiming_Liu
iomux setting:
MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12 0x00000140
We keep press the button (GPIO: HIGH->LOW)
then using systemctl suspend to enter suspend (GPIO stay LOW)
and then relase the button (GPIO: LOW->HIGH), system will be woken up
Is this correct?
2,770 次查看
Winslow
Hi @Zhiming_Liu
I saw this in source code
* The trigger type is always both edges for gpio-based keys and we do
* not support changing wakeup trigger for interrupt-based keys.
Does this mean that IRQ_TYPE_EDGE_FALLING is not working?
2,750 次查看
Zhiming_Liu
Hi @Winslow
Can you add below property to test? This will set wakeup event for IRQ_TYPE_EDGE_FALLING referring the source code.
wakeup-event-action = <EV_ACT_ASSERTED>;
Zhiming
2,748 次查看
Winslow
Hi @Zhiming_Liu
I did added this, but it's not working.
        BTN-wakeup {
            wakeup-source;
2,741 次查看
Zhiming_Liu
Hi @Winslow
I did test based on i.MX8MP FRDM platform, iomux value 0x1c4. Enter suspend with systemctl, then click button, keep it low, system will be waken up.
	sw-keys {
		compatible = "gpio-keys";
		K1: user_btn1 {
			label = "User Button1";
			gpios = <&gpio3 14 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
			interrupt-parent = <&gpio3>;
			interrupts = <14 IRQ_TYPE_EDGE_FALLING>;
			wakeup-source;
Zhiming
2,735 次查看
Winslow
Hi @Zhiming_Liu
could you help to try
1. click button, keep it low
2. systemctl suspend
3. release button (low -> high)
system will wakeup?
2,715 次查看
Zhiming_Liu
Hi @Winslow
I did such test steps for many times, the system will not wake up while LOW->HIGH. So at least on my side, rising edge will not work if setting failing edge in dts.
This should relate to hardware design, as i didn't find availble button on EVK board, so i test it on i.MX8MP FRDM board which has a user button.
Zhiming
2,705 次查看
Winslow
Hi @Zhiming_Liu
Thank you!
We will review our hardware design
%3CLINGO-SUB%20id%3D%22lingo-sub-2202316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20gpio%20%E5%94%A4%E9%86%92%E7%B1%BB%E5%9E%8B%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20imx8mp%20EVK%20%3C%2FSPAN%3E%3CSPAN%3ELinux%206.12.3_1.0.0%20%E5%B9%B6%E6%B5%8B%E8%AF%95%20gpio%20%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BD%93%E8%AE%BE%E7%BD%AE%20IRQ_TYPE_EDGE_FALLING%20%E6%97%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%20GPIO%20%E4%BB%8E%E4%BD%8E%E7%94%B5%E5%B9%B3%E5%8F%98%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%E6%97%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E8%A2%AB%E9%94%99%E8%AF%AF%E5%94%A4%E9%86%92%E3%80%82%3C%2FP%3E%3CP%3E(%E5%BA%94%E4%BB%85%E5%9C%A8%20GPIO%20%E4%BB%8E%E9%AB%98%E7%94%B5%E5%B9%B3%E5%8F%98%E4%B8%BA%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%97%B6%E5%94%A4%E9%86%92%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E5%9B%9E%E9%A1%BE%3CSPAN%3E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%81%9A%E4%BA%86%E5%BE%88%E5%A4%9A%E6%AC%A1%E8%BF%99%E6%A0%B7%E7%9A%84%E6%B5%8B%E8%AF%95%E6%AD%A5%E9%AA%A4%EF%BC%8C%E5%9C%A8%20LOW-%26gt%3BHIGH%20%E6%97%B6%E7%B3%BB%E7%BB%9F%E4%B8%8D%E4%BC%9A%E5%94%A4%E9%86%92%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%87%B3%E5%B0%91%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%9C%A8%20dts%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E5%A4%B1%E6%95%88%E8%BE%B9%E7%BC%98%EF%BC%8C%E5%88%99%E4%B8%8A%E5%8D%87%E6%B2%BF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%BA%94%E8%AF%A5%E4%B8%8E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E6%9C%89%E5%85%B3%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%9C%A8%20EVK%20%E4%B8%BB%E6%9D%BF%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%E5%8F%AF%E7%94%A8%E7%9A%84%E6%8C%89%E9%92%AE%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%9C%A8%E5%B8%A6%E6%9C%89%E7%94%A8%E6%88%B7%E6%8C%89%E9%92%AE%E7%9A%84%20i.mx8MP%20FRDM%20%E6%9D%BF%E4%B8%8A%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365380i5CB28C3E06748EAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1762994853485.png%22%20alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E8%AF%95%E4%B8%80%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E1.%3CSPAN%3E%E7%82%B9%E5%87%BB%E6%8C%89%E9%92%AE%EF%BC%8C%E4%BF%9D%E6%8C%81%E4%BD%8E%E9%80%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20systemctl%20suspend%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.%20%E7%89%88%E6%9C%AC%E6%8C%89%E9%92%AE%EF%BC%88%E4%BD%8E-%26gt%3B%20%E9%AB%98%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%B3%BB%E7%BB%9F%E4%BC%9A%E5%94%A4%E9%86%92%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40%E6%B8%A9%E6%96%AF%E5%A8%84%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9F%BA%E4%BA%8E%20i.MX8MP%20FRDM%20%E5%B9%B3%E5%8F%B0%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8Ciomux%20%E5%80%BC%E4%B8%BA%200x1c4%E3%80%82%E4%BD%BF%E7%94%A8%20systemctl%20%E8%BF%9B%E5%85%A5%E6%8C%82%E8%B5%B7%E7%8A%B6%E6%80%81%EF%BC%8C%E7%84%B6%E5%90%8E%E7%82%B9%E5%87%BB%E6%8C%89%E9%92%AE%EF%BC%8C%E4%BF%9D%E6%8C%81%E4%BD%8E%E6%A1%A3%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%B0%B1%E4%BC%9A%E8%A2%AB%E5%94%A4%E9%86%92%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09sw-keys%20%7B%0A%09%09compatible%20%3D%20%22gpio-keys%22%3B%0A%0A%09%09K1%3A%20user_btn1%20%7B%0A%09%09%09label%20%3D%20%22User%20Button1%22%3B%0A%09%09%09linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%09%09%09gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2014%20(GPIO_ACTIVE_LOW%20%7C%20GPIO_PULL_UP)%26gt%3B%3B%0A%09%09%09interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio3%26gt%3B%3B%0A%09%09%09interrupts%20%3D%20%26lt%3B14%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%09%09%09wakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%0A%09%09%09wakeup-source%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FKEY_WAKEUP%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%8A%A0%E4%BA%86%E8%BF%99%E4%B8%AA%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20BTN-wakeup%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20label%20%3D%20%22BTN-WAKEUP%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2012%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20debounce-interval%20%3D%20%26lt%3B10%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%7D%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FKEY_WAKEUP%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40%E6%B8%A9%E6%96%AF%E5%A8%84%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%B1%9E%E6%80%A7%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9F%E8%BF%99%E5%B0%86%3CSPAN%3E%E5%8F%82%E7%85%A7%E6%BA%90%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%E4%B8%BAIRQ_TYPE_EDGE_FALLING%E8%AE%BE%E7%BD%AE%E5%94%A4%E9%86%92%E4%BA%8B%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9C%8B%E5%88%B0%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E5%AF%B9%E4%BA%8E%E5%9F%BA%E4%BA%8E%20gpio%20%E7%9A%84%E5%AF%86%E9%92%A5%EF%BC%8C%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%B1%BB%E5%9E%8B%E5%A7%8B%E7%BB%88%E6%98%AF%E5%8F%8C%E5%90%91%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9E%E5%A6%82%E6%AD%A4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E4%B8%8D%E6%94%AF%E6%8C%81%E6%9B%B4%E6%94%B9%E5%9F%BA%E4%BA%8E%E4%B8%AD%E6%96%AD%E7%9A%84%E6%8C%89%E9%94%AE%E7%9A%84%E5%94%A4%E9%86%92%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20IRQ_TYPE_EDGE_FALLING%20%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%82%A8%E5%9C%A8%20iomux%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E4%B8%8A%E6%8B%89%E5%8A%9F%E8%83%BD%E5%90%97%EF%BC%9F%E8%AF%B7%E7%A1%AE%E4%BF%9D%E5%9C%A8%E7%82%B9%E5%87%BB%E6%8C%89%E9%92%AE%E5%89%8D%E8%AF%A5%20gpio%20%E4%BF%9D%E6%8C%81%E9%AB%98%E7%94%B5%E5%B9%B3%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E7%82%B9%E5%87%BB%E6%8C%89%E9%92%AE%E6%97%B6%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%20HIGH-%26gt%3BLOW%20%E4%BF%A1%E5%8F%B7%E3%80%82%E5%A6%82%E6%9E%9C%E5%9C%A8%E7%82%B9%E5%87%BB%E6%8C%89%E9%92%AE%E5%89%8D%E8%AF%A5%20gpio%20%E4%BF%9D%E6%8C%81%E4%BD%8E%E7%94%B5%E5%B9%B3%EF%BC%8C%E5%88%99%E8%AF%B4%E6%98%8E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%93%8D%E4%BD%9C%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%20%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20btn-wakeup%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20label%20%3D%20%22BTN-WAKEUP%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2012%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20debounce-interval%20%3D%20%26lt%3B10%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%7D%3B%3C%2FKEY_WAKEUP%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20irq%20%E6%AD%A3%E5%9C%A8%E8%AE%BE%E7%BD%AE%E4%B8%8B%E8%B7%8C%E5%92%8C%E4%B8%8A%E5%8D%87%E7%9A%84%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%9F%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eirqflags%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Eirqf_trigger_rising%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3Eirqf_trigger_falling%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3Edevm_request_any_context_irq%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88dev%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%3Ebdata%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3Eirq%3C%2FSPAN%3E%3CSPAN%3E%2C%20isr%2C%20irqflags%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edesc%EF%BC%8Cbdata%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40%E6%B8%A9%E6%96%AF%E5%A8%84%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20dts%20%E4%B8%AD%E9%85%8D%E7%BD%AE%20gpio%20%E5%94%A4%E9%86%92%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E9%87%8C%E6%98%AF%20drivers%2Finput%2Fkeyboard%2Fgpio_keys.c%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E8%BD%AC%E5%82%A8%20%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSTRONG%3Ebdata-%26gt%3B%3C%2FSTRONG%3E%3CSPAN%3E%3CSTRONG%3Ewakeup_trigger_type%3C%2FSTRONG%3E%E4%BB%A5%E7%A1%AE%E8%AE%A4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%E7%9C%9F%E5%AE%9E%E7%B1%BB%E5%9E%8B%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ebool%20active_low%20%3D%20gpiod_is_active_low(bdata-%26gt%3Bgpiod)%3B%09%09%0A%0Aswitch%20(button-%26gt%3Bwakeup_event_action)%20%7B%0A%09%09case%20EV_ACT_ASSERTED%3A%0A%09%09%09bdata-%26gt%3Bwakeup_trigger_type%20%3D%20active_low%20%3F%0A%09%09%09%09IRQ_TYPE_EDGE_FALLING%20%3A%20IRQ_TYPE_EDGE_RISING%3B%0A%09%09%09break%3B%0A%09%09case%20EV_ACT_DEASSERTED%3A%0A%09%09%09bdata-%26gt%3Bwakeup_trigger_type%20%3D%20active_low%20%3F%0A%09%09%09%09IRQ_TYPE_EDGE_RISING%20%3A%20IRQ_TYPE_EDGE_FALLING%3B%0A%09%09%09break%3B%0A%09%09case%20EV_ACT_ANY%3A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
