i.MX8MP gpio wakeup type issue
3,022件の閲覧回数
Winslow
I'm using imx8mp EVK Linux 6.12.3_1.0.0 and testing gpio wakeup
when setting IRQ_TYPE_EDGE_FALLING
The system is incorrectly woken up when the GPIO changes from low to high.
(It should be wakeup when GPIO changes from high to low only)
How can this problem be solved?
Thank you
11 返答(返信)
2,992件の閲覧回数
Zhiming_Liu
Hi @Winslow
How do you configure the gpio wakeup in dts?
Here is drivers/input/keyboard/gpio_keys.c source code, you can try to dump
bdata->wakeup_trigger_type to confirm real type in driver.
bool active_low = gpiod_is_active_low(bdata->gpiod);
switch (button->wakeup_event_action) {
		case EV_ACT_ASSERTED:
			bdata->wakeup_trigger_type = active_low ?
				IRQ_TYPE_EDGE_FALLING : IRQ_TYPE_EDGE_RISING;
			break;
		case EV_ACT_DEASSERTED:
				IRQ_TYPE_EDGE_RISING : IRQ_TYPE_EDGE_FALLING;
			break;
		case EV_ACT_ANY:
Zhiming
2,983件の閲覧回数
Winslow
Hi @Zhiming_Liu
my setting is
        btn-wakeup {
            label = "BTN-WAKEUP";
            gpios = <&gpio5 12 GPIO_ACTIVE_LOW>;
            linux,code = <KEY_WAKEUP>;
            debounce-interval = <10>;
            interrupt-parent = <&gpio5>;
            interrupts = <12 IRQ_TYPE_EDGE_FALLING>;
            wakeup-source;
Does this code means irq is setting trigger both falling and rising?
irqflags = IRQF_TRIGGER_RISING | IRQF_TRIGGER_FALLING;
error = devm_request_any_context_irq(dev, bdata->irq, isr, irqflags,
desc, bdata);
2,973件の閲覧回数
Zhiming_Liu
Hi @Winslow
Did you set the pull up in iomux setting? and make sure that this gpio stay high before your click the button. Otherwise, there is no HIGH->LOW signal when you click button. If this gpio stays low before you click the button, the driver's action is correct.
Zhiming
2,968件の閲覧回数
Winslow
Hi @Zhiming_Liu
iomux setting:
MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12 0x00000140
We keep press the button (GPIO: HIGH->LOW)
then using systemctl suspend to enter suspend (GPIO stay LOW)
and then relase the button (GPIO: LOW->HIGH), system will be woken up
Is this correct?
2,942件の閲覧回数
Winslow
Hi @Zhiming_Liu
I saw this in source code
* The trigger type is always both edges for gpio-based keys and we do
* not support changing wakeup trigger for interrupt-based keys.
Does this mean that IRQ_TYPE_EDGE_FALLING is not working?
2,922件の閲覧回数
Zhiming_Liu
Hi @Winslow
Can you add below property to test? This will set wakeup event for IRQ_TYPE_EDGE_FALLING referring the source code.
wakeup-event-action = <EV_ACT_ASSERTED>;
Zhiming
2,920件の閲覧回数
Winslow
Hi @Zhiming_Liu
I did added this, but it's not working.
        BTN-wakeup {
            wakeup-source;
2,913件の閲覧回数
Zhiming_Liu
Hi @Winslow
I did test based on i.MX8MP FRDM platform, iomux value 0x1c4. Enter suspend with systemctl, then click button, keep it low, system will be waken up.
	sw-keys {
		compatible = "gpio-keys";
		K1: user_btn1 {
			label = "User Button1";
			gpios = <&gpio3 14 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
			interrupt-parent = <&gpio3>;
			interrupts = <14 IRQ_TYPE_EDGE_FALLING>;
			wakeup-source;
Zhiming
2,907件の閲覧回数
Winslow
Hi @Zhiming_Liu
could you help to try
1. click button, keep it low
2. systemctl suspend
3. release button (low -> high)
system will wakeup?
2,887件の閲覧回数
Zhiming_Liu
Hi @Winslow
I did such test steps for many times, the system will not wake up while LOW->HIGH. So at least on my side, rising edge will not work if setting failing edge in dts.
This should relate to hardware design, as i didn't find availble button on EVK board, so i test it on i.MX8MP FRDM board which has a user button.
Zhiming
2,877件の閲覧回数
Winslow
Hi @Zhiming_Liu
Thank you!
We will review our hardware design
%3CLINGO-SUB%20id%3D%22lingo-sub-2202316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20gpio%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eimx8mp%20EVK%3C%2FSPAN%3E%20%3CSPAN%3ELinux%206.12.3_1.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6GPIO%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIRQ_TYPE_EDGE_FALLING%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGPIO%20%E3%81%8C%E4%BD%8E%E3%81%8B%E3%82%89%E9%AB%98%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%AA%A4%E3%81%A3%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88GPIO%E3%81%8C%E3%83%8F%E3%82%A4%E3%81%8B%E3%82%89%E3%83%AD%E3%83%BC%E3%81%AB%E5%A4%89%E5%8C%96%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%81%BF%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%A7%A3%E6%B1%BACAN%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%3CSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%E3%82%92%E8%A6%8B%E7%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%95%E5%BA%A6%E3%82%82%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81LOW-%26gt%3BHIGH%20%E3%81%AE%E9%96%93%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SO%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81dts%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%82%A8%E3%83%83%E3%82%B8%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8B%20i.MX8MP%20FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365380i5CB28C3E06748EAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1762994853485.png%22%20alt%3D%22Zhiming_Liu_0-1762994853485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E1.%3CSPAN%3E%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E4%BD%8E%E3%81%8F%E4%BF%9D%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20systemctl%20%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E9%9B%A2%E3%81%99%EF%BC%88%E4%BD%8E%E2%86%92%E9%AB%98%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Ei.MX8MP%20FRDM%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%80%81iomux%20%E5%80%A4%200x1c4%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82systemctl%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E4%BD%8E%E3%81%84%E4%BD%8D%E7%BD%AE%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09sw-keys%20%7B%0A%09%09compatible%20%3D%20%22gpio-keys%22%3B%0A%0A%09%09K1%3A%20user_btn1%20%7B%0A%09%09%09label%20%3D%20%22User%20Button1%22%3B%0A%09%09%09linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%09%09%09gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2014%20(GPIO_ACTIVE_LOW%20%7C%20GPIO_PULL_UP)%26gt%3B%3B%0A%09%09%09interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio3%26gt%3B%3B%0A%09%09%09interrupts%20%3D%20%26lt%3B14%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%09%09%09wakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%0A%09%09%09wakeup-source%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FKEY_WAKEUP%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20BTN-wakeup%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20label%20%3D%20%22BTN-WAKEUP%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2012%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20debounce-interval%20%3D%20%26lt%3B10%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%7D%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FKEY_WAKEUP%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%3CSPAN%3E%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%20IRQ_TYPE_EDGE_FALLING%20%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewakeup-event-action%20%3D%20%3CEV_ACT_ASSERTED%3E%3B%3C%2FEV_ACT_ASSERTED%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E*%20GPIO%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AF%E5%B8%B8%E3%81%AB%E4%B8%A1%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81IRQ_TYPE_EDGE_FALLING%20%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20iomux%20%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%20GPIO%20%E3%81%8C%E3%83%8F%E3%82%A4%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%20HIGH-%26gt%3BLOW%20%E4%BF%A1%E5%8F%B7%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%81%93%E3%81%AE%20GPIO%20%E3%81%8C%E4%BD%8E%E3%81%84%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20btn-wakeup%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20label%20%3D%20%22BTN-WAKEUP%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2012%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccode%20%3D%20%3CKEY_WAKEUP%3E%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20debounce-interval%20%3D%20%26lt%3B10%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%7D%3B%3C%2FKEY_WAKEUP%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81irq%20%E3%81%8C%E4%B8%8B%E9%99%8D%E3%81%A8%E4%B8%8A%E6%98%87%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eirqflags%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EIRQF_TRIGGER_RISING%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EIRQF_TRIGGER_FALLING%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Edevm_request_any_context_irq%3C%2FSPAN%3E%20%3CSPAN%3E(dev%2C%3C%2FSPAN%3E%20%3CSPAN%3Ebdata%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3Eirq%3C%2FSPAN%3E%20%3CSPAN%3E%2C%20isr%2C%20irqflags%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edesc%2C%20bdata)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20gpio%20wakeup%20type%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248522%22%20target%3D%22_blank%22%3E%40Winslow%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Edts%20%E3%81%A7%20gpio%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Finput%2Fkeyboard%2Fgpio_keys.c%E3%81%A7%E3%81%99%E3%80%82%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%83%80%E3%83%B3%E3%83%97%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BCAN%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSTRONG%3Ebdata-%26gt%3B%3C%2FSTRONG%3E%20%3CSPAN%3E%3CSTRONG%3Ewakeup_trigger_type%3C%2FSTRONG%3E%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ebool%20active_low%20%3D%20gpiod_is_active_low(bdata-%26gt%3Bgpiod)%3B%09%09%0A%0Aswitch%20(button-%26gt%3Bwakeup_event_action)%20%7B%0A%09%09case%20EV_ACT_ASSERTED%3A%0A%09%09%09bdata-%26gt%3Bwakeup_trigger_type%20%3D%20active_low%20%3F%0A%09%09%09%09IRQ_TYPE_EDGE_FALLING%20%3A%20IRQ_TYPE_EDGE_RISING%3B%0A%09%09%09break%3B%0A%09%09case%20EV_ACT_DEASSERTED%3A%0A%09%09%09bdata-%26gt%3Bwakeup_trigger_type%20%3D%20active_low%20%3F%0A%09%09%09%09IRQ_TYPE_EDGE_RISING%20%3A%20IRQ_TYPE_EDGE_FALLING%3B%0A%09%09%09break%3B%0A%09%09case%20EV_ACT_ANY%3A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
