i.MX8MP adding HD3SS3220 Type-C cause Wake on LAN failed
1,762 次查看
AlanWen
I'm working on the 6.12.34 kernel and modifying the kernel device tree imx8mp-evk.dts.
nxp-imx/imx-manifest: i.MX Release Manifest (imx-linux-walnascar)
When added the hd3ss3220 type-c controller in the device tree as follow, WOL failed.
connector {
		compatible = "usb-c-connector";
		label = "USB-C";
		data-role = "dual";
		status = "disabled";
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				hs_ep: endpoint {
					remote-endpoint = <&usb3_hs_ep>;
			port@1 {
				reg = <1>;
				ss_ep: endpoint {
					remote-endpoint = <&hd3ss3220_in_ep>;
&iomux {
pinctrl_hd3ss3220: hd3ss3220grp {
		fsl,pins = <
			MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12	0x140
&i2c2 {
clock-frequency = <400000>;
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_i2c2>;
	status = "okay";
hd3ss3220@67 {
		compatible = "ti,hd3ss3220";
		reg = <0x67>;
		pinctrl-0 = <&pinctrl_hd3ss3220>;
		interrupt-parent = <&gpio5>;
		interrupts = <12 IRQ_TYPE_LEVEL_LOW>;
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				hd3ss3220_in_ep: endpoint {
					remote-endpoint = <&ss_ep>;
			port@1 {
				reg = <1>;
				hd3ss3220_out_ep: endpoint {
					remote-endpoint = <&usb3_role_switch>;
&usb_dwc3_1 {
	dr_mode = "otg";
	hnp-disable;
	srp-disable;
	adp-disable;
	usb-role-switch;
	status = "okay";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			usb3_hs_ep: endpoint {
				remote-endpoint = <&hs_ep>;
		port@1 {
			reg = <1>;
			usb3_role_switch: endpoint {
				remote-endpoint = <&hd3ss3220_out_ep>;
The WOL function failed after calling the suspend command.
As I checked the wake up is supported
root@imx8mpevk:~# ethtool -s eth0 wol g
root@imx8mpevk:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP    MII ]
        Supported link modes:   10baseT/Full
                                100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Full
                                100baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             100baseT/Half 100baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Auto-negotiation: on
        master-slave cfg: preferred slave
        master-slave status: slave
        Port: Twisted Pair
        PHYAD: 1
        Transceiver: external
        MDI-X: Unknown
        Supports Wake-on: ug
        Wake-on: g
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
root@imx8mpevk:~# dmesg | grep -i wake
[    3.148381] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[   13.933830] stmmac: wakeup enable
root@imx8mpevk:~# cat /sys/class/net/eth0/device/power/wakeup
enabled
But the same setting of the device tree on 6.6.52 kernel (imx-linux-scarthgap) worked well !!
Could anybody help me ?
6 回复数
1,581 次查看
Zhiming_Liu
Hi @AlanWen ,
I checked the HD3SS3220 dts node, the HD3SS3220 driver is using IRQF_TRIGGER_FALLING, can you try to use IRQ_TYPE_EDGE_FALLING in dts? And set MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12 to 0x1c4.
	if (client->irq > 0) {
		ret = devm_request_threaded_irq(&client->dev, client->irq, NULL,
					hd3ss3220_irq_handler,
					IRQF_TRIGGER_FALLING | IRQF_ONESHOT,
					"hd3ss3220", &client->dev);
Zhiming
1,577 次查看
AlanWen
There is a syntax error while compiling the linux-imx kernel device tree.
It seem to be no definition of "IRQF_TRIGGER_FALLING", do I need to include a file ?
1,534 次查看
Zhiming_Liu
Please try to use IRQ_TYPE_EDGE_FALLING in dts.
Zhiming
1,491 次查看
AlanWen
Although changing the interrupt signal as "IRQ_TYPE_EDGE_FALLING", the wake-up function still didn't work.
Currently, the wake-up function worked well using the following setup.
    connector {
		label = "USB-C";
		data-role = "dual";
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				hs_ep: endpoint {
			port@1 {
				reg = <1>;
				ss_ep: endpoint {
&i2c2 {
	status = "okay";
	hd3ss3220@67 {
		reg = <0x67>;
		wakeup-source;
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
			port@1 {
				reg = <1>;
&iomux {
		fsl,pins = <
			MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12	0x140 // USB_SW_INTn (AH20)
&usb3_phy1 {
	fsl,phy-tx-preemp-amp-tune-microamp = <1800>;
	fsl,phy-tx-vref-tune-percent = <116>;
	status = "okay";
&usb3_1 {
	status = "okay";
&usb_dwc3_1 {
	dr_mode = "otg";
	hnp-disable;
	srp-disable;
	adp-disable;
	usb-role-switch;
	role-switch-default-mode = "host";
	snps,dis-u1-entry-quirk;
	snps,dis-u2-entry-quirk;
	status = "okay";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
		port@1 {
			reg = <1>;
But as you can see, the connector's status is set as "disabled", why ?
When we remove this line, the wake-up function failed.
1,440 次查看
Zhiming_Liu
Hi @AlanWen
In my personal opinion, this issue is likely related to the upgrade of kernel generic components and should not be attributed to i.MX-related drivers. Since I don't have the same hardware platform, I can't pinpoint exactly where the problem lies.
Zhiming
1,322 次查看
AlanWen
But the wakeup function was worked in 6.6.52 kernel version using the same setup without the connector status line.
As follow:
    connector {
		label = "USB-C";
		data-role = "dual";
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				hs_ep: endpoint {
			port@1 {
				reg = <1>;
				ss_ep: endpoint {
&i2c2 {
	status = "okay";
	hd3ss3220@67 {
		reg = <0x67>;
		wakeup-source;
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
			port@1 {
				reg = <1>;
&iomux {
		fsl,pins = <
&usb3_phy1 {
	status = "okay";
&usb3_1 {
	status = "okay";
&usb_dwc3_1 {
	dr_mode = "otg";
	hnp-disable;
	srp-disable;
	adp-disable;
	usb-role-switch;
	status = "okay";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
		port@1 {
			reg = <1>;
%3CLINGO-SUB%20id%3D%22lingo-sub-2270332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20%E6%B7%BB%E5%8A%A0%20HD3SS3220%20Type-C%20%E5%AF%BC%E8%87%B4%20LAN%20%E5%94%A4%E9%86%92%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%206.12.34%20%E5%86%85%E6%A0%B8%E5%B9%B6%E4%BF%AE%E6%94%B9%E5%86%85%E6%A0%B8%E8%AE%BE%E5%A4%87%E6%A0%91%20imx8mp-evk.dts%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Enxp-imx%2Fimx-Manifest%EF%BC%9Ai.MX%20%E7%89%88%E6%9C%AC%E6%B8%85%E5%8D%95%20(imx-linux-wal%3C%2FA%3E%20%3CSPAN%3Enascar)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%8C%89%E5%A6%82%E4%B8%8B%E6%96%B9%E5%BC%8F%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E6%B7%BB%E5%8A%A0%20hd3s3220%20type-c%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%EF%BC%8CWOL%20%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%7B%0Aconnector%20%7B%0A%09%09compatible%20%3D%20%22usb-c-connector%22%3B%0A%09%09label%20%3D%20%22USB-C%22%3B%0A%09%09data-role%20%3D%20%22dual%22%3B%0A%09%09status%20%3D%20%22disabled%22%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_hs_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09ss_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_in_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Biomux%20%7B%0Apinctrl_hd3ss3220%3A%20hd3ss3220grp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12%090x140%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bi2c2%20%7B%0Aclock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c2%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0Ahd3ss3220%4067%20%7B%0A%09%09compatible%20%3D%20%22ti%2Chd3ss3220%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x67%26gt%3B%3B%0A%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_hd3ss3220%26gt%3B%3B%0A%09%09interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%09%09interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_LEVEL_LOW%26gt%3B%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_in_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bss_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_out_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_role_switch%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%20%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Busb_dwc3_1%20%7B%0A%09dr_mode%20%3D%20%22otg%22%3B%0A%09hnp-disable%3B%0A%09srp-disable%3B%0A%09adp-disable%3B%0A%09usb-role-switch%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09ports%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09port%400%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09usb3_hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhs_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%09port%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09usb3_role_switch%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_out_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%B0%83%E7%94%A8%E6%8C%82%E8%B5%B7%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8CWOL%20%E5%8A%9F%E8%83%BD%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E6%A3%80%E6%9F%A5%EF%BC%8C%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%E6%98%AF%E5%8F%97%E6%94%AF%E6%8C%81%E7%9A%84%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A~%23%20ethtool%20-s%20eth0%20wol%20g%0Aroot%40imx8mpevk%3A~%23%20ethtool%20eth0%0ASettings%20for%20eth0%3A%0A%20%20%20%20%20%20%20%20Supported%20ports%3A%20%5B%20TP%20%20%20%20MII%20%5D%0A%20%20%20%20%20%20%20%20Supported%20link%20modes%3A%20%20%2010baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20100baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%201000baseT%2FFull%0A%20%20%20%20%20%20%20%20Supported%20pause%20frame%20use%3A%20Symmetric%20Receive-only%0A%20%20%20%20%20%20%20%20Supports%20auto-negotiation%3A%20Yes%0A%20%20%20%20%20%20%20%20Supported%20FEC%20modes%3A%20Not%20reported%0A%20%20%20%20%20%20%20%20Advertised%20link%20modes%3A%20%2010baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20100baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%201000baseT%2FFull%0A%20%20%20%20%20%20%20%20Advertised%20pause%20frame%20use%3A%20Symmetric%20Receive-only%0A%20%20%20%20%20%20%20%20Advertised%20auto-negotiation%3A%20Yes%0A%20%20%20%20%20%20%20%20Advertised%20FEC%20modes%3A%20Not%20reported%0A%20%20%20%20%20%20%20%20Link%20partner%20advertised%20link%20modes%3A%20%2010baseT%2FHalf%2010baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20100baseT%2FHalf%20100baseT%2FFull%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%201000baseT%2FFull%0A%20%20%20%20%20%20%20%20Link%20partner%20advertised%20pause%20frame%20use%3A%20Symmetric%0A%20%20%20%20%20%20%20%20Link%20partner%20advertised%20auto-negotiation%3A%20Yes%0A%20%20%20%20%20%20%20%20Link%20partner%20advertised%20FEC%20modes%3A%20Not%20reported%0A%20%20%20%20%20%20%20%20Speed%3A%201000Mb%2Fs%0A%20%20%20%20%20%20%20%20Duplex%3A%20Full%0A%20%20%20%20%20%20%20%20Auto-negotiation%3A%20on%0A%20%20%20%20%20%20%20%20master-slave%20cfg%3A%20preferred%20slave%0A%20%20%20%20%20%20%20%20master-slave%20status%3A%20slave%0A%20%20%20%20%20%20%20%20Port%3A%20Twisted%20Pair%0A%20%20%20%20%20%20%20%20PHYAD%3A%201%0A%20%20%20%20%20%20%20%20Transceiver%3A%20external%0A%20%20%20%20%20%20%20%20MDI-X%3A%20Unknown%0A%20%20%20%20%20%20%20%20Supports%20Wake-on%3A%20ug%0A%20%20%20%20%20%20%20%20Wake-on%3A%20g%0A%20%20%20%20%20%20%20%20Current%20message%20level%3A%200x0000003f%20(63)%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20drv%20probe%20link%20timer%20ifdown%20ifup%0A%20%20%20%20%20%20%20%20Link%20detected%3A%20yes%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A~%23%20dmesg%20%7C%20grep%20-i%20wake%0A%5B%20%20%20%203.148381%5D%20imx-dwmac%2030bf0000.ethernet%3A%20Wake-Up%20On%20Lan%20supported%0A%5B%20%20%2013.933830%5D%20stmmac%3A%20wakeup%20enable%0Aroot%40imx8mpevk%3A~%23%20cat%20%2Fsys%2Fclass%2Fnet%2Feth0%2Fdevice%2Fpower%2Fwakeup%0Aenabled%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%206.6.52%20%E5%86%85%E6%A0%B8%EF%BC%88%3CSPAN%3Eimx-linux-%3C%2FSPAN%3E%20scarthgap%EF%BC%89%E4%B8%8A%E5%90%8C%E6%A0%B7%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E8%AE%BE%E7%BD%AE%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%EF%BC%81%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%81%E8%83%BD%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2270332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20adding%20HD3SS3220%20Type-C%20cause%20Wake%20on%20LAN%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%9C%A8%20dts%20%E4%B8%AD%E4%BD%BF%E7%94%A8%3CSTRONG%3EIRQ_TYPE_EDGE_FALLING%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20adding%20HD3SS3220%20Type-C%20cause%20Wake%20on%20LAN%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%99%BD%E7%84%B6%E5%B0%86%E4%B8%AD%E6%96%AD%E4%BF%A1%E5%8F%B7%E6%94%B9%E4%B8%BA%22%3CSTRONG%3EIRQ_TYPE_EDGE_FALLING%3C%2FSTRONG%3E%22%20%EF%BC%8C%E4%BD%86%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%E4%BB%8D%E7%84%B6%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%20%20%20%20connector%20%7B%0A%09%09compatible%20%3D%20%22usb-c-connector%22%3B%0A%09%09label%20%3D%20%22USB-C%22%3B%0A%09%09data-role%20%3D%20%22dual%22%3B%0A%09%09status%20%3D%20%22disabled%22%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_hs_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09ss_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_in_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bi2c2%20%7B%0A%09clock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c2%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09hd3ss3220%4067%20%7B%0A%09%09compatible%20%3D%20%22ti%2Chd3ss3220%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x67%26gt%3B%3B%0A%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_hd3ss3220%26gt%3B%3B%0A%09%09interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%09%09interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_LEVEL_LOW%26gt%3B%3B%0A%09%09wakeup-source%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_in_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bss_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_out_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_role_switch%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%20%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Biomux%20%7B%0A%20%20%20%20pinctrl_hd3ss3220%3A%20hd3ss3220grp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12%090x140%20%2F%2F%20USB_SW_INTn%20(AH20)%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Busb3_phy1%20%7B%0A%09fsl%2Cphy-tx-preemp-amp-tune-microamp%20%3D%20%26lt%3B1800%26gt%3B%3B%0A%09fsl%2Cphy-tx-vref-tune-percent%20%3D%20%26lt%3B116%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Busb3_1%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Busb_dwc3_1%20%7B%0A%09dr_mode%20%3D%20%22otg%22%3B%0A%09hnp-disable%3B%0A%09srp-disable%3B%0A%09adp-disable%3B%0A%09usb-role-switch%3B%0A%09role-switch-default-mode%20%3D%20%22host%22%3B%0A%09snps%2Cdis-u1-entry-quirk%3B%0A%09snps%2Cdis-u2-entry-quirk%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09ports%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09port%400%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09usb3_hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhs_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%09port%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09usb3_role_switch%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_out_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E4%BD%86%E5%A6%82%E4%BD%A0%E6%89%80%E8%A7%81%EF%BC%8C%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%9A%84%E7%8A%B6%E6%80%81%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%22%3CSTRONG%3Edisabled%3C%2FSTRONG%3E%22%20%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%88%A0%E9%99%A4%E8%BF%99%E4%B8%80%E8%A1%8C%E5%90%8E%EF%BC%8C%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%E5%B0%B1%E5%A4%B1%E6%95%88%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20adding%20HD3SS3220%20Type-C%20cause%20Wake%20on%20LAN%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223292%22%20target%3D%22_blank%22%3E%40AlanWen%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E6%88%91%E4%B8%AA%E4%BA%BA%E8%AE%A4%E4%B8%BA%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E4%B8%8E%E5%86%85%E6%A0%B8%E9%80%9A%E7%94%A8%E5%85%83%E5%99%A8%E4%BB%B6%E7%9A%84%E5%8D%87%E7%BA%A7%E6%9C%89%E5%85%B3%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%BD%92%E5%9B%A0%E4%BA%8E%20i.MX%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E7%94%B1%E4%BA%8E%E6%88%91%E6%B2%A1%E6%9C%89%E7%9B%B8%E5%90%8C%E7%9A%84%E7%A1%AC%E4%BB%B6%E5%B9%B3%E5%8F%B0%EF%BC%8C%E6%89%80%E4%BB%A5%E6%97%A0%E6%B3%95%E5%87%86%E7%A1%AE%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MP%20adding%20HD3SS3220%20Type-C%20cause%20Wake%20on%20LAN%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%86%E5%9C%A8%206.6.52%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%9C%A8%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%8A%B6%E6%80%81%E8%A1%8C%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%E4%B9%9F%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%20%20%20%20connector%20%7B%0A%09%09compatible%20%3D%20%22usb-c-connector%22%3B%0A%09%09label%20%3D%20%22USB-C%22%3B%0A%09%09data-role%20%3D%20%22dual%22%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_hs_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09ss_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_in_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bi2c2%20%7B%0A%09clock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c2%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09hd3ss3220%4067%20%7B%0A%09%09compatible%20%3D%20%22ti%2Chd3ss3220%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x67%26gt%3B%3B%0A%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_hd3ss3220%26gt%3B%3B%0A%09%09interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio5%26gt%3B%3B%0A%09%09interrupts%20%3D%20%26lt%3B12%20IRQ_TYPE_LEVEL_LOW%26gt%3B%3B%0A%09%09wakeup-source%3B%0A%0A%09%09ports%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_in_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bss_ep%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%09%09%09port%401%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09%09hd3ss3220_out_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Busb3_role_switch%26gt%3B%3B%0A%09%09%09%09%7D%3B%0A%20%09%09%09%7D%3B%0A%20%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Biomux%20%7B%0A%20%20%20%20pinctrl_hd3ss3220%3A%20hd3ss3220grp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12%090x140%20%2F%2F%20USB_SW_INTn%20(AH20)%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Busb3_phy1%20%7B%0A%09fsl%2Cphy-tx-preemp-amp-tune-microamp%20%3D%20%26lt%3B1800%26gt%3B%3B%0A%09fsl%2Cphy-tx-vref-tune-percent%20%3D%20%26lt%3B116%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Busb3_1%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Busb_dwc3_1%20%7B%0A%09dr_mode%20%3D%20%22otg%22%3B%0A%09hnp-disable%3B%0A%09srp-disable%3B%0A%09adp-disable%3B%0A%09usb-role-switch%3B%0A%09role-switch-default-mode%20%3D%20%22host%22%3B%0A%09snps%2Cdis-u1-entry-quirk%3B%0A%09snps%2Cdis-u2-entry-quirk%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09ports%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%09port%400%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09usb3_hs_ep%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhs_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%09port%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09usb3_role_switch%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bhd3ss3220_out_ep%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
