i.MX8M mini SW calibration issue
已解决
跳至解决方案
2,273 次查看
Tori-san
Hello, According to the IMX8MMRM.pdf clause 5.4.5, software calibration method use Tcalib as part of the alpha. What means Tcalib in denominator of alpha? Is it a mistake in TE2? Tcalib_SW = alpha x (Tsense - TE1) + 25 alpha = (85-25)/(Tcalib - TE1)
1 解答
2,241 次查看
Yuri
@Tori-san
  yes, correct.
Yuri.
在原帖中查看解决方案
3 回复数
2,261 次查看
Yuri
@Tori-san
  yes, formula is incorrect  (misprint),  if Tcalib is not measured at 85 C.
Yuri.
2,247 次查看
Tori-san
Hi Yuri, Thank you for your reply. I think the following formula is also correct but how do you think of it? Tcalib_SW = ((85-25)/(TE2-TE1)) x (Tsense - TE2) + 85 Best regards, Tori-san.
2,242 次查看
Yuri
@Tori-san
  yes, correct.
Yuri.
