i.MX8M PLUS CPLD Design?
935 次查看
armmey
Hi, I have a question while reviewing the use of I.MX8M PLUS. I want to connect XC9572XL to I.MX8M PLUS (address & data).
In case of using I.MX6 SOLO, CPLD is controlled by connecting to External Interface Module (EIM).
In case of I.MX8M PLUS, EIM Interface group is not visible.
Could you please explain in detail how to design an 8-bit address decoder?
887 次查看
June_Lu
May you could use FlexSPI which could support FPGA/CPLD devices.
You could refer to
 https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Expend-i-MX8M-93-Capability-to-Connect-F...
