i.MX8M Nano with 4 GB LPDDR4 DRAM
Wobaffet
Senior Contributor I
We want to use 4GB ram with our i.MX8M Nano design. I could not able to find any product from Micron website. 4GB ram only seems to available for x32 is there a x16 solution for this? Thank you in advance!
Gencay
Wobaffet
I couldn't find such information on the datasheets, we need 4GB ram for our project, can you recommend any part number?
Best regards.
riteshmpatel
Hi @Wobaffet,
One can refer to the i.MX8M Nano EVK schematic from below-mentioned link. In the EVK, 2GB DDR4 is used. However, NXP doesn't suggest any specific vendor. One can contact the memory vendors as per their requirements.
https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/evaluation-kit-...
Thanks & Regards,
Ritesh M Patel
riteshmpatel
Hi @Wobaffet,
I hope you are doing well.
Kindly contact the memory vendors to find the best suitable part for your application. For list of supported DDR memory, one can refer to the i.MX8M Nano datasheet from below link.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
Thanks & Regards,
Ritesh M Patel
