i.MX8M Mini error
i.MX8M Mini error
1,630件の閲覧回数
lizboxy
Hi,Sir
I got the error on the i.MX8M Mini, any adrise for the error?TKs!i.MX8M Mini.bmp
1,577件の閲覧回数
Hi George
one can check processor datasheet and dts fsl-imx8mm.dtsi
A53_0 {
operating-points = <
/* kHz    uV */
fsl-imx8mm.dtsi\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
cpufreq driver description can be found in Linux Manual in
Linux 4.19.35_1.1.0 Documentation
1,577件の閲覧回数
lizboxy
So next step what should I do? Any ill effect for this?TKs!
