i.MX8M调用失败
i.MX8M调用失败
1,277 次查看
lizboxy
请教一下,通过调试发现,在函数 cdns_mhdp_training_start(struct cdns_mhdp_device *mhdp) 里面读取事件发现: if (event[1] & CLK_RECOVERY_FAILED) DRM_DEV_ERROR(mhdp->dev, "clock recovery failed\n"); else if (event[1] & EQ_PHASE_FINISHED) return 0; 这里失败的只要原因是 event[1]=0x40 即 EQ_PHASE_FAILED 请问这个是因为什么呢?
1 回复
1,261 次查看
jimmychan
Could you tell me more detail information about your question?
What version of BSP are you using?
Which board are you using?
Which source code are you talking about?
