i.MX8 Tensorflow C++
4,754件の閲覧回数
weilly_li
      Rencenly,  I want to compile C/C++ DEMO about label_image of Tensorflow .
      But This document getting information is too old , Can you tell me usage about tensorflow 2.4.1  ? Thank
PDF : NXP eIQ™ Machine Learning Software Development Environment for i.MX Applications Processors
Weilly
4,665件の閲覧回数
weilly_li
Dear All,
I solved this problem about the newest bsp can't compile tensorflow DEMO issue by myself.
Please follow step
(1) Build BSP L5.10.35.2.0.0 SDK of i.MX8MPlus
      $ source ./imx-setup-release.sh -b bld-xwayland      $ Add in local.conf
         IMAGE_INSTALL_append += " packagegroup-imx-ml"
         TOOLCHAIN_TARGET_TASK_append += "tensorflow-lite-dev armnn-dev  onnxruntime-dev"
      $  bitbake -c populate_sdk imx-image-full
       Tip :  tensorflow-lite-staticdev package has some problem for this version
(2) Install SDK
      $  cd /home/weilly/fsl-yocto-8mp/bld-xwayland/tmp/deploy/sdk
      $ ./fsl-imx-xwayland-glibc-x86_64-imx-image-full-cortexa53-crypto-imx8mpevk-toolchain-5.10-hardknott.sh
(3) Setting Environment
     $ source /opt/fsl-imx-xwayland/5.10-hardknott/environment-setup-cortexa53-crypto-poky-linux
(4) Download Tensorflow Lite Source Code
     $ git clone https://github.com/tensorflow/tensorflow
     $ git checkout v2.4.0
(5) Compile Code
     $ cd /tensorflow/tensorflow/lite/examples/label_image
    $ $CC -o label_image_weilly label_image.cc bitmap_helpers.cc ../../tools/evaluation/utils.cc \
        -I=/usr/include/tensorflow/lite/tools/make/downloads/flatbuffers/include \
        -I=/usr/include/tensorflow/lite/tools/make/downloads/absl \
        -ltensorflow-lite -lstdc++ -lpthread -lm -ldl -lrt
here, Share.
Weilly
5 返答(返信)
4,745件の閲覧回数
Bio_TICFSL
Hello Weilly_li
The documentation includes tensorflow 1.12v because is the version installed on the NU of the MX8MP, there is no actualization to 2.4v but in general the demo should work.
4,666件の閲覧回数
weilly_li
Dear All,
Please follow step
(2) Install SDK
(5) Compile Code
here, Share.
Weilly
4,687件の閲覧回数
weilly_li
Hi, @Bio_TICFSL
      還有什麼方式可以幫忙解決嗎? 不然無法生出 SDK ~ 去編譯 Tensorflow ~感恩
Weilly
4,704件の閲覧回数
weilly_li
Hi, @Bio_TICFSL
      i have confirmed add it . so I know this toolchian's problem of "tensorflow-lite-staticdev"
      BSP : L5.10.35.2.0.0
      Platform : NXP i.MX8MPlus
Weilly
4,733件の閲覧回数
weilly_li
Dear Bio_TICFSL,
Thank your reply!!  but I still need newest compile method of tensorflow c++ .
Today, I tryed compile label_image code using bazel, it can work on i.MX8M Plus. Unfortunately this method can't use NPU ....do you have some suggest ?
Weilly Li
