i.MX8 LPDDR4
i.MX8 LPDDR4
1,504 次查看
santosh_t
We are using MIMX8MM3CVTKZAA in our design. In the EVK file of i.MX8 (SPF-31399), referring to DDR section,  all the lines of Channel A of LPDDR4 is connected to Channel B of processor. For example pin H4(CS0_A) of LPDDR4 is connected to V4(CS0_B) of processor. Is it intentional? What is the reason behind this?
Thanks & Regards,
Santosh Tuppad
标签 (1)
1 回复
1,403 次查看
Hi SANTOSH
both channels are equal, so seems change was made due to board routing convenience.
