i.MX6ULL Compile Error
9,324件の閲覧回数
ray_deng1
Dears,
  I did separate compiled for imx-yocto-LF_L5.4.3_1.0.0, and already downloaded all the required components, but when it show below error.
| make[2]: *** No rule to make target 'arch/arm/boot/dts/imx6ull-14x14-evk-usb-certi.dtb'.  Stop.
Attached the error log for your reference,
Thanks &BRs,
Ray
7 返答(返信)
8,954件の閲覧回数
donoldham
I am have the same problem. Followed the procedure in the latest NXP yocto guide Rev. L5.4.24_2.1.0, 06/2020
$ mkdir imx-yocto-bsp
$ cd imx-yocto-bsp
$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest
-b imx-linux-zeus -m imx-5.4.24-2.1.0.xml
$ repo sync
DISTRO=fsl-imx-fb MACHINE=imx6ull14x14evk source imx-setup-release.sh -b build
bitbake core-image-minimal
I tried different images, but still get the error
"scripts/kconfig/conf --syncconfig Kconfig"
"make[2]: *** No rule to make target 'arch/arm/boot/dts/imx6ull-14x14-evk-usb-certi.dtb'. Stop"
".../build/tmp/work-shared/recipe for target 'imx6ull-14x14-evk-usb-certi.dtb' failed".
8,954件の閲覧回数
joanxie
for 6ull, try to use 5.4.3_1.0.0
8,953件の閲覧回数
radhikasomaiya
Senior Contributor II
Hi [email protected] ,
From Table 1. i.MX Yocto project images of attached yocto project user's guide imx-image-full is not supported on i.MX6ULL. These images are only supported for i.MX SoC with hardware graphics, So you cannot build imx-image-full for i.MX6ULL.
Radhika Somaiya.
8,953件の閲覧回数
ray_deng1
Hi Radhika,
Got it , thanks,
BRs,
Ray Deng
Field Application
South FAE,Avnet China
深圳市宝安区新安街道创业二路与留仙一路交汇处东侧创芯研发中心1栋5楼
5th Floor, Building 1, Wise R&D Center, Liuxian 1st Road cross Chuangye 2nd Road,69th Block, Boa ’an District,Shenzhen City
O +8675586342385
M +8618026960272
D +8675586342385
F +867558378.0826
avnet.com<https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Favnet.com%2F&data=02%7C01%7Cws.wong%40nxp.com%7Cb1694567060e40ace47208d59de6bc7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636588536688437382&sdata=%2ByRoHs0%2FqgD%2BDwbxAes4iThAy8ghHMQ1AaWisaRqYqs%3D&reserved=0>
发件人: [email protected] <[email protected]>
发送时间: 2020年5月12日 14:19
收件人: Deng, Ray <[email protected]>
主题: Re: - Re: i.MX6ULL Compile Error
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
reply from Radhika Somaiya<https://community.nxp.com/people/[email protected]?et=watches.email.thread> in i.MX Processors - View the full discussion<https://community.nxp.com/message/1310405?commentID=1310405&et=watches.email.thread#comment-1310405>
8,953件の閲覧回数
joanxie
what build commands do you use? pls share this, let me double check it
8,953件の閲覧回数
radhikasomaiya
We are able to build with imx-yocto-LF_L5.4.3_1.0.0 for i.MX6ULL14x14evk. Our host system is ubuntu 16.04.
Our configurations are as per below:
     Distro : fsl-imx-wayland
     Machine : imx6ull14x14evk
We have tried both images.
     Image 1 : core-image-minimal
     Image 2 : fsl-image-machine-test
We have followed the steps from Yocto project User's guide.(You can download document's from below link).
https://www.nxp.com/webapp/Download?colCode=L5.4.3_1.0.0_LINUX_DOCS
Can you please give us the steps which you have followed?
Radhika Somaiya.
8,953件の閲覧回数
ray_deng1
Hi Radhika,
Thanks for your response. I use below configurations,
Distro : fsl-imx-fb
Machine : imx6ullevk
Image 1 : imx-image-full
BRs,
Ray Deng
Field Application
O +8675586342385
M +8618026960272
D +8675586342385
F +867558378.0826
发件人: Radhika Somaiya <[email protected]>
发送时间: 2020年5月12日 0:09
主题: You have been mentioned by Radhika Somaiya in Re: i.MX6ULL Compile Error in NXP Community
by Radhika Somaiya<https://community.nxp.com/people/[email protected]?et=notification.mention> in Re: i.MX6ULL Compile Error in NXP Community - View Radhika Somaiya's reference to you<https://community.nxp.com/message/1310130?commentID=1310130&et=notification.mention#comment-1310130>
