Kernel 4.1.15
Customer try to decrease the kernel size by remove some configuration and found kernel panic after remove CONFIG_SMP when reboot.
kernel configuration with CONFIG_SMP (imx6sll_deconfig_SMP=y.txt)
kernel configuration without CONFIG_SMP (imx6sll_deconfig_SMP=n.txt)
kernel configuration diff (imx6sll_config_SMP.diff / config_diff.png)
start_reboot_start_log.txt
kill_crash_dmesg.txt
Solved! Go to Solution.
Hi m.c.
standard way described in nxp documentation is to use
command-line option of 'nosmp' or 'maxcpus=0' will disable SMP.
For issues with kernel configurations (as this is general linux issue)
suggest post question on kernel mail list
Majordomo Lists at VGER.KERNEL.ORG
Hi m.c.
